cruise not working
Old Oct 10, 2007 | 8:51 PM
kenneth1976's Avatar
Default cruise not working
Hi im new looking for some info. i have a 2004 silverado 2500 and the cruise control has gone out. I have already checked the fuses by the door and that was good. If anyone has any ideas i could use the help. Thanks
Old Oct 11, 2007 | 8:41 AM
RonH's Avatar
Default RE: cruise not working
Possible failure pointsinclude the multi-function switch (turn signal lever with all the switches), thePowertrain Control Module,and theCruise Control Module, or it could be aconnector in the wiring harness. You will probably need to have someone do a diagnostic check on the cruise control system topinpoint what's not working right rather than to just start throwing parts at it trying to accidently hit theproblem.
Old Oct 21, 2007 | 8:58 PM
98chevy's Avatar
Check the brake peddle switch first.
Old Oct 21, 2007 | 9:33 PM
V1 Dave's Avatar
This one might sound a little funny but I have a 93 Caprice and when the center brake light burns out my cruise control stops working.
Let me know if this works!
Old Oct 21, 2007 | 9:37 PM
bu11dog13795's Avatar
i would check the wireing !!! but between fueses and wires you should find your problem i am having a similar problem with my radio,gueges and auto lights lol good luck and take your time
Old Oct 22, 2007 | 4:54 PM
how do you check the brake pedal switch to see if its good with out just replacing it.
Old Oct 22, 2007 | 11:42 PM
golfer's Avatar
ORIGINAL: kenneth1976
With an ohm meter.
Old Oct 23, 2007 | 10:15 AM
RonH's Avatar
The low-tech method is to have someone watch the brake lights to see if they work properly while you press and releasethe pedal.
mossyoak
16
Apr 12, 2023 8:40 AM
KC-RUNNER
Dec 18, 2009 8:36 PM
chevyridinghi
Jun 4, 2009 8:07 PM
marilove
Oct 13, 2008 8:15 PM
AviD
Jun 26, 2007 10:41 AM
