door problems
Old Feb 4, 2007 | 12:24 PM
spaceman's Avatar
Default door problems
My son's 94 step side's passenger door would not open so he drilled a hole 5" below the key hole and pressed down on a small release lever and the door opened properly. Now the driver's door has done the same thing but when he drilled the hole and pressed down on the little lever the door latch does not release allowing the door to open. I am thinking I might cut a hole in the cab right behind the door catch latch "post" and see if it has a nut on the back that can be removed so the door can then open the the problem found and resolved but that nut may be attached to the cab so it cannot be turned/removed. Any suggestions?
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
mwehrste
Dec 29, 2014 11:19 AM
aquaholic
Nov 21, 2008 1:21 PM
arctic_94
Jul 1, 2008 9:23 PM
83_Caprice_Classic
Jul 20, 2006 1:32 AM
