Heat problems!! Please help !!
Old Jan 20, 2013 | 5:04 PM
Tlindsey099's Avatar
Arrow Heat problems!! Please help !!
About a month ago my truck sensor said I was overheating. Naturally I got some anti freeze and put some in the radiator and the overflow. The next day the truck was not pushing warm air in the cab. (It had before) I found out my radiator had a leak and that's why I was overheating, so I changed the radiator, the thermostat (195 degree), the water pump, the heater core and my blend door moves, I can hear it. Now the fan speed **** only works on high, I have no idea if this is relevant to my problem but I have tried everything I can think of.
My truck is a 1995 K1500
Please help with suggestions. Thanks
Old Jan 21, 2013 | 2:20 AM
branndonn's Avatar
Check The Fuses !!!
Old Jan 23, 2013 | 11:28 PM
cleveland63b's Avatar
more than likely your blower motor resistor, see if theres power out of it on any other setting.
Old Jan 24, 2013 | 1:21 AM
LvTitan's Avatar
My,blower only blows, on high or on 2 also, since I owned truck? 98 . I recently put new t-stat in cause wasn't getting warm enough. Now I have 150 deg air nice, but my 195 stat still opens at like 155, and truck still runs cooler than should. Tested w/ non contact can't afford scan tool. Sounds and seems like my fan clutch always engaged too is that common ? Sorry for hijacked
Old Jan 24, 2013 | 5:46 PM
The fan still runs on high but no warm air. What would the resistor do?
Old Jan 24, 2013 | 8:44 PM
The Fan is fine; it moves and the fluids are moving though all the hoses (Both HC and radiator hoses) so no air pockets.
Old Jan 24, 2013 | 8:47 PM
you have 2 issues, the resistor (most likely) will fix the blower so all speeds work.
as far as the no heat feel hoses, in and out of the radiator and same with the heater core and also just because you put a new tstat in doesn't mean its a good 1. Does the gauge read where it should? A scanner would be very helpful to see the ECT reading
Old Jan 24, 2013 | 8:55 PM
I understand the fan now, that's fine. Later date. Thanks you Its very cold is MO, I just want heat right now, lol
The gauge reads well it sits just before 210 (half) when it's been running for a while.
Muskovin
10
Feb 27, 2020 6:45 AM
jmarkv
Jan 24, 2012 8:21 PM
thehig
Uplander
Nov 26, 2009 9:11 PM
tumark
Apr 15, 2007 12:58 PM
