horn blowing fuses
Old Aug 8, 2012 | 10:08 PM
jblahuta's Avatar
Default horn blowing fuses
my 2002 chevrolet silverado 1500hd is blowing fuses when i blow the horn. i even tried putting a 20amp fuse instead of a 15amp fuse and my horn will blow once and then the fuse will blow. does anyone have an idea where to start looking to see what the problem is. thanks in advance...
Old Aug 9, 2012 | 12:42 AM
jesse06's Avatar
you need to get a continuity tester and test your wires from end to end, find which wire has a short.
Old Aug 9, 2012 | 7:35 AM
Jeff Collision's Avatar
I suggest you to inspect the fuse to see if the silver colored band inside is melted or broken, indicating a blown fuse, and also check your owner's manual ahead of time to locate the fuse and keep extra fuses on hand for any important electrical functions.
Old Aug 9, 2012 | 8:37 AM
jblahuta's Avatar
i have checked the fuse and it blows right away after one honk of horn. even went up a size and it blew as soon as i got one honk.
i am trying to locate a wiring diagram for my truck to try and shoot the wires. i just have not been able find a good wiring schematic to do so with
Thanks for all the replys so far they are greatly appreciated.
Old Aug 9, 2012 | 11:04 AM
kevinkpk's Avatar
Probably the horn. Disconnect, install new fuse, then hit the horn. If it dosen't blow the fuse, replace the horn
Old Aug 9, 2012 | 10:16 PM
jesse06's Avatar
ya could call the local dealership and ask if they can print ya a copy of the wiring diagram for it. I've got the 1988-1998 wiring diagram book if ya wanna copy i could email you a scan
Old Aug 9, 2012 | 10:22 PM
jesse06's Avatar
here is a scan of the horn wiring schematic for 88-99
Old Aug 10, 2012 | 8:15 AM
jblahuta's Avatar
awesome thanks for the help. i will try disconnecting the horn tonight and see what happens. also, thanks for the schematic. i will look at it and see if it matches. cant see why it would be to much different. thanks again for all the help so far.
Old Nov 20, 2012 | 2:38 PM
jessica696912's Avatar
It is better to check the wire properly. Their might be any short circuit. Or buy new horn and all the parts from warning lights.
flukester
Aug 31, 2012 4:38 PM
netty
Oct 23, 2009 12:04 AM
isaac_22
Dec 26, 2007 9:23 PM
mychevyvan
Oct 23, 2006 1:02 PM
