injector wont work
Old Jan 25, 2012 | 10:04 PM
pinedale's Avatar
Default injector wont work
I have a 2000 chevy 3/4 ton truck with a 5.7l engine. Im hoping some one here can help me, I had a bad injector so I replaced them with the delphi conversion. the #6 injector is not getting power to it> I swapped the injectors to be sure of the problem. Im assuming theres a short somewhere in the harness and I am dreading searching for it. Is it possible that its something else? any help will be greatly appreciated.
Old Jan 25, 2012 | 10:28 PM
EinST's Avatar
Welcome to the forum. A short would blow the ECM1 fuse in the underhood fuse block. All fuel injectors are supplied a battery voltage over the PNK wire with key on. The VCM will then ground the other side to energize a particular injector. For the "#6 injector" it's the YEL/BLK wire that goes to connector C2, terminal 16. See if you can measure the voltage on the PNK wire against a known good ground with key on. If voltage absent, there's your problem. If not, there's probably a break on the other wire that goes to the VCM.
Old Jan 26, 2012 | 9:42 PM
pinedale's Avatar
Thanks very much for your help. I had 2 injectors not having continuity to the computer so I spliced new ones that I ran along the harness and now the truck is running great
Old Jan 26, 2012 | 9:57 PM
EinST's Avatar
Wow, that was some quick diagnostic work. Thanks for the update.
goyakpacking
May 9, 2015 7:51 PM
mukherjee_mk
Aug 28, 2012 11:18 PM
LeeA
Apr 13, 2012 4:28 AM
uncledave11
Sep 10, 2010 7:12 AM
