misfire
Old Apr 22, 2007 | 7:40 PM
slvrpny's Avatar
Default misfire
03 1500HD crew 75,000 highway miles. Engine warning light comes on at 65mph and above goes off below 65.The code says misfire on #1 and #6.The truck has new plugs/wires the dealer checked the coils,injectors and sensors. The dealer suspects carbon build up on valves and the only way to confirm this is with a $600.00 tear down and then a $2000.00 plus valve job to fix the problem. I know there is an induction cleaner but the dealer doubts that it will work. What if I don't fix it? I burn quality fuel ( BP and Mobil) use full synthetic oil there is no reason I should be doing major engine work at 75,000 miles. Any other options? Thanks in advance.
Old Apr 22, 2007 | 7:59 PM
matador's Avatar
Default RE: misfire
Is this a diesel?
Old Apr 22, 2007 | 8:39 PM
slvrpny's Avatar
Default RE: misfire
Sorry 6.0 liter gas.
Old Apr 22, 2007 | 9:29 PM
Hippie's Avatar
Default RE: misfire
is there just a miss fire when cold or hot the 5.3 &6.0 have intake leak problems leaking vacuum causing
miss fire codes
Old Apr 22, 2007 | 11:56 PM
sm3earl's Avatar
Default RE: misfire
Are you using crappy gas, IE arco, discount gas? because those cause lots of carbon to build up.
Old Apr 23, 2007 | 12:05 AM
slvrpny's Avatar
Default RE: misfire
Only quality fuel (BP or Mobil). Light only flashes at 65 and above engine is hot. I don't know the codes but I'll find out.
Old Jul 9, 2007 | 2:43 PM
MCOLLINS72022's Avatar
Default RE: misfire
so how do you know if you have a intake leak i have a 2004 2500hd with a 6.0liter in it and I am have a lean code po171 and p0300 random misfire code the frist thing i thougth was vac. leaks but did not find any. does any one have any ideas?
Old Jul 9, 2007 | 2:48 PM
sm3earl's Avatar
Default RE: misfire
MCOLLINS72022,
Start a new post for more feedback.
Old Jul 10, 2007 | 9:08 PM
cj23's Avatar
Default RE: misfire
Had same problem at about 70mph code read misfire change injectors on cylinder with the misfire no more problem. Since I know how to do it that's why I did mine's you may want to try a injector flush first.
[/align]
buddyleno
Mar 31, 2017 8:13 AM
Biggumzmcgee
Nov 15, 2009 10:51 AM
JetSnake
Jul 14, 2009 2:43 PM
akimber
14
Aug 22, 2006 11:45 AM
bmc257
Jul 7, 2006 3:21 AM
