oil change
Old Jan 22, 2008 | 11:51 AM
ragin_cajuns's Avatar
Default oil change
i'm changing the oil in my 07 nbs silverado for the first time tonight. anything i need to know before i get under there? this should be an easy truck to change the oil on right?
what size wrench will i need for the drain plug?
thanks,
Old Jan 22, 2008 | 12:55 PM
ZX1100F1's Avatar
Default RE: oil change
15mm wrench to unscrew the drain plug, don't forget to wipe the magnetic tip off as well.
It is very straight forward on these trucks and since the oil filter is mounted vertically you can pre-fill it with oil which will reduce oil pressure pump up time.
Old Jan 22, 2008 | 6:28 PM
there are two 15mm bolts on opposite sides of each other but at the same position where it look slike oil could drain. is the drain plllug the one closest to the filter [nearer the drivers sde]or the other [nearer the passenger side]?
magnetic tip?
Old Jan 23, 2008 | 1:22 AM
SplitOTE17's Avatar
yeah its pretty straight forward, just remember ur basic tips for changing oil
me and my dad take a chizel and hammer and punch a small hole in the filter before you unscrew it to prevent oil from spilling on you
Old Jan 23, 2008 | 2:26 PM
ehhget's Avatar
That is a good idea about punching a hole in the filter to pre-drain- Damn hundreds of oil changes gone messy- I cant beleive I never thought of that.
Old Jan 23, 2008 | 3:13 PM
marta52's Avatar
ORIGINAL: ehhget
good idea - thank you!
Old Jan 23, 2008 | 4:09 PM
slc10844's Avatar
Loosen the filter before you punch the hole. You don't want to punch the hole first and not be able to unscrew the filter.
Old Jan 24, 2008 | 7:13 PM
SplitOTE17's Avatar
yeah we break it loose first and then punch the hole
in2pro
Nov 19, 2015 5:36 PM
PeterPiper
Sonic (Aveo)
17
Feb 6, 2010 1:10 PM
Toby T
Mar 14, 2008 5:16 PM
Big D
Jan 10, 2008 6:53 PM
digdug
Feb 4, 2007 3:08 PM
