ready lift kits
Old Jul 18, 2014 | 8:39 PM
jonnythebeard's Avatar
Default ready lift kits
i have a 2012 chevy silverado 1500. anybody put the 4in front n the 1.75in rear readylift kit in there silverado? im having some problems with the front.
Old Jul 20, 2014 | 10:21 PM
country_09's Avatar
Well what's it doin?
Old Jul 21, 2014 | 9:40 AM
welll i putthe new upper a arm in n the strut with the spacer. n now the sway bar is way to high to bolt back up to stock spot n the tierod ends r on a steep angle. i heard abot the tierod ends being like that but not even tec at readylift can help me with the sway bar. should i loosen the whole thing up n swing down? u ever put on of these lifts in?
Old Jul 22, 2014 | 10:19 PM
country_09's Avatar
Sounds like you should've got longer sway bar links with the kit. That'll fix that problem. The tie rods, well that's cause the ready lift 4" is a glorified leveling kit. They give you upper arms to account for the upper ball joint angle, but do nothin about the bottom ball join, tie rods, or cv angles if you're 4wd. Only way to fix that is get a full suspension lift, or beef em up with some ffr heim tie rods.
Old Jul 23, 2014 | 10:43 AM
so it looks like readylift is a bs artist. they say this kit is the only thing u need. thanks
Old Jul 24, 2014 | 4:56 AM
country_09's Avatar
I wouldn't say bs, lot of people have run their kits. They're pretty reputable. But I've seen people have problems out of the over stretched levelin kit "lifts". Rough country has one and I believe fabtech does too, along with ready lift. They correct the upper ball joint angle, but do nothin to correct the tie rods, lower ball joint, and CV angles if you're 4wd. Ends up causin lots of problems later. If I were you I'd see about returnin it, or sell it, and buyin a 5" rough country suspension lift. That's a proven full lift and it's not very tall
Old Jul 25, 2014 | 10:29 AM
Yea im giving it to today n im gonna take it out n see if i can return it. U interested in buying it lol ?
Old Jul 25, 2014 | 4:51 PM
country_09's Avatar
Lol don't have a need for it but some else will. Smaller lifts like that sell quick
mrpete
Feb 24, 2014 7:50 PM
Brocko04
Jun 12, 2011 9:27 AM
SGTMIKE270
Sep 22, 2010 11:28 AM
akepple
May 11, 2009 11:03 AM
04sublt
Nov 26, 2008 2:12 PM
