Torsion Keys
Torsion Keys
I have a 05 1500 witha 4'' suspension lift and i wanted to get it higher without doing a body lift. can i put new torsion keys in even thought i have the suspension lift? please help me.
Thanks
Travis
Thanks
Travis
well the keys do the same exact thing as turnin up the stock keys all they do in put more tension on the torsion bars so j-man is right they are a wast of money and time
crankin them up i believe stiffens your ride...as where i did..i wanted a lil lower stance on the front end...in turn it made it a little spongey in the front end...could just be my set up but i think thats the way it goes
trevor
trevor
Cranking your t-bars will do the EXACT same thing as new keys. You are putting more torque on the bar's to achieve the lift. Bad? Maybe, maybe not. If you go for about 1-1.5" of lift, you will be fine. Anything more and you will put your CV shafts and ball-joints at bad angles causing excessive wear. The ride will stiffen slightly as you are adding more pressure on the bars and slightly decreasing your suspension droop. Having said that, I have my t-bars cranked on my Colorado for a total of about 2+" 75,000+ miles and no problems.
Jman
So if i crank the bars 1.5 inches should i still put 6 inch blocks in the back because i have the 4 inch blocks already. or should i get 5.5 inch blocks. doesnt superlift make 5.5 inch blocks?
Thanks
Travis
Thanks
Travis
ukrkoz
November 14th, 2011 9:03 AM
aftershock00
January 28th, 2008 1:39 PM
