Torsion Keys
Old Feb 12, 2009 | 4:15 PM
L.O.S.T 1500's Avatar
Default Torsion Keys
I have a 05 1500 witha 4'' suspension lift and i wanted to get it higher without doing a body lift. can i put new torsion keys in even thought i have the suspension lift? please help me.
Thanks
Travis
Old Feb 12, 2009 | 6:16 PM
J-man67's Avatar
You should be able to crank your stock keys if they are not already. Keys are a waste of money IMO as you can achieve the same thing without them.
Old Feb 13, 2009 | 1:25 PM
x1cn18's Avatar
well the keys do the same exact thing as turnin up the stock keys all they do in put more tension on the torsion bars so j-man is right they are a wast of money and time
Old Feb 13, 2009 | 3:38 PM
isnt cranking your torsion bars bad for your truck???
Old Feb 14, 2009 | 3:03 PM
CaptTrevStarr's Avatar
crankin them up i believe stiffens your ride...as where i did..i wanted a lil lower stance on the front end...in turn it made it a little spongey in the front end...could just be my set up but i think thats the way it goes
trevor
Old Feb 15, 2009 | 5:18 PM
tubbz56's Avatar
do you tighten the keys to make it a little higher and stiffer or do you losen the keys????
Old Feb 17, 2009 | 2:49 PM
J-man67's Avatar
Cranking your t-bars will do the EXACT same thing as new keys. You are putting more torque on the bar's to achieve the lift. Bad? Maybe, maybe not. If you go for about 1-1.5" of lift, you will be fine. Anything more and you will put your CV shafts and ball-joints at bad angles causing excessive wear. The ride will stiffen slightly as you are adding more pressure on the bars and slightly decreasing your suspension droop. Having said that, I have my t-bars cranked on my Colorado for a total of about 2+" 75,000+ miles and no problems.
Old Feb 17, 2009 | 9:56 PM
Jman
So if i crank the bars 1.5 inches should i still put 6 inch blocks in the back because i have the 4 inch blocks already. or should i get 5.5 inch blocks. doesnt superlift make 5.5 inch blocks?
Thanks
Travis
Duenas&BigBertha
Dec 16, 2011 9:20 PM
ukrkoz
Nov 14, 2011 9:03 AM
rdtj
Nov 18, 2010 12:29 AM
FLSTFI
Mar 28, 2008 1:03 PM
aftershock00
Jan 28, 2008 1:39 PM
