won't go into tow mode
Old Apr 28, 2009 | 10:53 AM
sammy's Avatar
Default won't go into tow mode
I have a 2000 silverado 4x4. The tow mode doesn't work most of the time. Anyone else have this problem?
Old Apr 28, 2009 | 6:20 PM
gpssurvey's Avatar
Hi Sammy,
There is sort of a known wear-point for the wiring for the tow mode button. This link does a pretty good job of summing up the issue.
http://www.justanswer.com/questions/...hased-used-tow
Hope this helps!
Old Apr 28, 2009 | 9:25 PM
jherkel's Avatar
did you check the fuse? there could be a blown fuse either under your hood in the electrical center or on the side of the dash behind the fuse cover on the driver side. if the fuse is good try looking for a loose wire or disconnected wire. thats all i can tell ya.
Old Apr 28, 2009 | 10:03 PM
suzuki-guy's Avatar
If the fuse was bad it wouldnt work at all not sometimes sounds like a short to me
Old Apr 29, 2009 | 12:53 PM
sammy's Avatar
The 4x4 switch on the dash took a dump on my way to work during a snow storm. It had been acting up I replaced it and founf 3 blown fuses. I thought maybe this was the problem it didn't fix it.
Old Apr 29, 2009 | 1:24 PM
sammy's Avatar
Thanks for info I will check this stuff this weekend. Suzuki guy what kind of suzuki do you have. I have a Samuria I built up for off roading.
Old Apr 29, 2009 | 5:12 PM
suzuki-guy's Avatar
i have a quad its a LT250r bored 60 over
Old Apr 30, 2009 | 9:04 AM
sammy's Avatar
I have an 88 Samuria with a 6" lift 31" tires locked front and rear with a gear reduction set in the tranfer case. I Also have Polaris and Honda 4x4 atvs my kids ride. I take my Samuria out with the local ATV club on rides, not a lot of places I can't follow.
georam1
Oct 17, 2011 7:44 PM
mummp
Oct 13, 2009 8:48 PM
steved
Nov 27, 2007 1:27 AM
racerx55
May 17, 2007 8:05 AM
Clay24
Jan 4, 2007 1:37 AM
