Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
AVEO 2009 T255 - Problems after coldstart?
Old May 11, 2020 | 9:07 AM
Herbert Lego's Avatar
Default AVEO 2009 T255 - Problems after coldstart?
Hello everybody,
following problem with my AVEO T255, 63,000km mileage, 1.4, 101HP from 2009.
The engine speed is out of round for a few moments after the cold start. The speed increases to just over 1000rpm - but only for a few seconds. After that, the engine remains calm at 900rpm. Is this normal for the engine?
New in February:
- Lambda sensor
- spark plugs (without ignition cable)
Thanks in advance and greetings from Germany.
Old May 11, 2020 | 1:58 PM
is the rubber hose from the air filter to the throttle body torn. they tear on the bottom from repeated flexing when the air filter is checked. this would create a lean condition at idle which you can see in the fuel trim data. the bigger concern is unfiltered air entering the engine.
Old May 11, 2020 | 2:14 PM
Hi, thanks for the answer! I'll check the rubber hose from the air filter tomorrow. It is strange - yesterday the car was very restless after the cold start, i.e. significant speed fluctuations at approx 21 degrees outside temperature. I just had a cold start again, and the speed is a bit higher, but remains stable for now.
I also made a video. Do you hear the sound at 4sec?
jtdreiki
Sonic (Aveo)
24
Mar 8, 2017 11:13 AM
tomwalt
Sonic (Aveo)
Apr 19, 2015 11:25 AM
AfterHoursAuto
Sonic (Aveo)
Sep 13, 2014 4:56 PM
speed
Sonic (Aveo)
Nov 16, 2010 2:24 AM
tony_co1
Sonic (Aveo)
May 25, 2010 9:44 AM
