07" Suburban oil gulping!
Old Sep 10, 2016 | 3:20 AM
  #61
Doug_Dornbos's Avatar
Originally Posted by Lodestar
The long and short of it......it is much cheaper to take this route first before considering a rebuild.
I am shocked that more people don't think this way but so many people don't that it is actually refreshing to see it in print. Thanks for your pragmatism. I ordered a valve cover today.
Doug
Old Sep 11, 2016 | 9:37 AM
  #62
Lodestar's Avatar
Default Oil Gulping
Glad to be of assistance Doug. I like to keep my money close to my bank account too!
Old Sep 17, 2019 | 7:02 PM
  #63
Christopher Bosch's Avatar
Originally Posted by magician
Just curious about that "updated valve cover", can it be installed on an 07-08 5.3 AFM motor?
As far as the PCV, I thought this engine uses a PCV orrifice type system which is just a tube really? Not sure why you would want to replace that when simply cleaning would be effective?
My 07 has 206k on it and uses or consumes about half a quart of oil every 2k and has since I bought it. Compression numbers are in the 185-195 range on all 8 and the shield was installed somewhere along the line before I bought it. I plan on keeping it till it leaves me stranded.
I remove the valve cover on a 6.2 Vortec and remove the flash metal that covers the so call PVC port gently in side there's chunks of black build up which carries al lots of oil. In there is only a little tube with a little hole nothing else, I clean put back together and soon to test it. I might do other side
damone
May 8, 2021 12:36 PM
Platinum
Jan 16, 2019 9:53 PM
chevyman323
Jul 16, 2010 11:56 AM
mike688
Uplander
Jan 25, 2010 12:16 PM
