07 Tahoe Power Liftgate Problem
Old Dec 15, 2012 | 9:10 PM
silverlx's Avatar
Default 07 Tahoe Power Liftgate Problem
My power lift gate has began to act up. First when it opened it would make a loud bang at tue very top just before it stopped. Then it refused to close when I punched the button. It would make noise for a second but wouldn't close automatically. Now it'll still open with power but when it opens all the way it begins to bang loudly at the top and jumps up and down several inches over amd over again and then closes very quickly. I'm not really sure where to start with this issue. Any suggestions?
Old Dec 15, 2012 | 9:18 PM
My guess is there some mechanical issues in the drive mechanism. Missing teeth maybe.
Old Dec 16, 2012 | 11:16 AM
might also consider replacing the hatch struts if they are original... they get weak over time and even more so when its cold... use extreme caution when removing them, the hatch is very heavy... use a 2x4 to support it and make sure its not supported by the glass for obvious reasons....
Old Dec 18, 2012 | 8:16 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> silverlx,
I’m sorry you are experiencing this issue with your Tahoe vehicle. The other posters offer some great suggestions. Another possibility is the Power Liftgate Module may need to be reprogrammed.
I recommend consulting with a certified technician for an official diagnosis and repair option(s).
Louis
GM Customer Service
Old May 3, 2015 | 6:08 PM
pucduck's Avatar
I am having issues with my 2007 Tahoe power liftgate. It opens, near the top it makes grinding noises, then closes halfway, then all the way back to top, then closes itself all the way.
Scotiapilot
Apr 17, 2015 2:35 PM
The_Stees
Mar 5, 2013 8:20 AM
truckramrod
12
Mar 29, 2011 7:35 PM
doo600
Jan 9, 2007 4:57 PM
jbcobb
Nov 14, 2006 7:18 PM
