08 Tahoe Transmission issues
Old Apr 1, 2019 | 1:57 PM
TSMidwest's Avatar
Default 08 Tahoe Transmission issues
Hi, new member but I have been to the forums on multiple occasions thanks to Google lol.
Here is what we have going on, a bit of a long read:
Our 08 Tahoe has been having a grinding sound coming from the transmission when reversing. I found that while reversing, if I pulled down slightly on the shifter, the noise would stop. After driving the vehicle for a while, the noise would also go away for the day.
On top of that, there were times that shifting INTO park would be tough and take more effort than should have been needed.
The grinding noise seemed to me like when shifting straight into reverse, the parking pawl wasn't getting all the way disengaged, so the pulling down on the shifter or shifting into drive and then back up to reverse was able to "fix" that problem.
The other day, the wife went to pick up our daughter, and after putting the tahoe in park, she was unable to shift OUT of park. After multiple attempts, I was able to get it to shift by jacking up the tahoe slightly (enough to relieve any pressure on the parking pawl from the slight hill she had parked on).
There are no issues in drive or neutral.
My question is this. Does this sound like possibly a transmission cable going bad or that is out of adjustment? Or something more serious?
Thanks!
Old Apr 1, 2019 | 3:16 PM
retsub's Avatar
Not sure about the noise. If you are not shutting down this way then start doing it every time even on level ground. Stop with the right foot on brake, hold it down, shift to N, Left foot down on a working Parking Brake to set it then shift to Park. Try this and see if it is easier to get out of Park the next time. Good habit to follow. Good luck. *BW*
Old Feb 15, 2025 | 1:34 PM
Bradd2011's Avatar
Default Same issues
Thanks!
hey i had some of the same issues with my 2008 chevrolet tahoe ltz and when I would put it into park it wouldn't catch at all it ended up being a bad transfer case i changed it and all of my problems were fixed
Fish Killer
Apr 16, 2025 10:01 PM
Jheine
Jan 17, 2025 9:46 PM
afarnsworth
Aug 28, 2015 10:56 AM
jimthesoundman
Jan 3, 2012 11:04 AM
silver_E98
Aug 20, 2007 11:47 PM
