1997 suburban blower shuts down
Old Aug 27, 2020 | 11:06 PM
trund's Avatar
Default 1997 suburban blower shuts down
Hi Guys,
So, I put my blower on the highest fan setting, and the AC works great. Then, all of a sudden, it just stops. Poof, the blower just stops blowing. Is it overheating? Why?
I turn the dial counter-clockwise to lower fan speeds, and they all work. After a few minutes on a low speed, I switch back to the highest fan speed and it works again.
Help please !! What's going on here?
Thanks,
Ted
Old Aug 28, 2020 | 12:12 AM
usually signs of a failing motor. Remove and inspect. If bad, replace it or else it will burn up other expensive components.
Old Aug 30, 2020 | 12:13 AM
trund's Avatar
thx Joe for the tip. I'll give it a shot.
Old Jul 15, 2021 | 9:29 AM
oilcanhenry's Avatar
It's a Suburban, so it has a rear evaporator as well. 40 PSI over 225 PSI is totally normal for a C/K-1500-2500 pickup, but with a rear evaporator, that changes the game into a different ballpark, as it has a Thermal Expansion Valve in the rear. That said it could be a bad electrical relay in the engine compartment fuse and relay box under the hood on the driver's side on the fender.
Judd Boswell
Nov 16, 2019 9:18 AM
Ventura76
Oct 1, 2019 6:32 PM
Trav Harrell
2007 - 2013 (GMT900)
Jun 10, 2017 7:36 PM
chevywilly
Nov 26, 2014 6:05 PM
ashlinproperties@yahoo.com
May 11, 2010 8:50 PM
