1999 Suburban No Start
Old Jun 27, 2013 | 8:14 PM
billywhite45's Avatar
Unhappy 1999 Suburban No Start
I have a 1999 Suburban with a no start. Has been tuned, new fuel pump, turns over good but does not start. Getting fire to plugs and fuel. At times it sounds like it wants to start but won't. Any help greatly appreciated. Thanks in advance.
Old Jun 27, 2013 | 9:09 PM
RichC10's Avatar
Have you checked compression? Read the codes? Double check the fuel pressure, you can borrow a tester from a lot of auto parts stores. What is the history, has it run well recently? Check the basics, like plug wires routed correctly. If you are getting fuel at good pressure and spark at the right time, it would run.
Old Jun 28, 2013 | 7:05 AM
At times it will start and run good until you turn the motor off. It might start and run good when you try to start it or it might have to set a few days and it will start and run. When it starts it runs perfectly.
Old Jun 30, 2013 | 3:24 PM
Chartdog's Avatar
Question is too wide open at this point. Rich10 has the right direction. The basics are the basics for a reason.
Fuel, spark and compression. Has to be one of these. Are there codes?
Old Jun 30, 2013 | 9:37 PM
Sledgehammer's Avatar
crankshaft position sensor. So easy to replace and often overlooked . any many times to remedy for your issues
Old Jul 1, 2013 | 10:36 AM
Default Suburban
Fuel, spark and compression. Has to be one of these. Are there codes?[/QUOTE]
There are no codes.
Old Jul 1, 2013 | 10:37 AM
Can thge crankshaft position sensor go out and not set a code?
Old Jul 1, 2013 | 2:29 PM
MAny times it does not throw a code. (most of the time actually) and no cel
Old Jul 8, 2013 | 7:20 AM
ebacon's Avatar
Sounds like it is somehow flooded/not getting air.
jackeagles
May 30, 2013 10:33 PM
mvalentino
Mar 14, 2013 11:37 AM
Corsairball
Nov 24, 2012 12:45 AM
motojedi97
Oct 15, 2011 8:23 PM
bracca
Jul 12, 2009 6:14 PM
