1999 suburban ses light
Old Nov 5, 2012 | 7:09 PM
armystrong928's Avatar
Default 1999 suburban ses light
ok when i let my suburban idle for a few min it throws a ses light and it comes up as p0305(misfire cylinder 5) ive been fighting this code for a while it use to stay on all the time. i have done plugs, wires, cap, rotor, fuel filter, and MFI coversion on the injectors. i know when i hit the gas hard while moving the light goes off. when it is setting still like parked it comes back on. I was thinking it could be the o2 sensor on the driver side but not sure. does anyone have any ideas?
Old Nov 5, 2012 | 7:12 PM
kevinkpk's Avatar
could be the injector
Old Nov 5, 2012 | 7:14 PM
injectors are brand new
Old Nov 5, 2012 | 7:15 PM
shamrock246's Avatar
whats the compression on that cyl and the other ones next to it?
Old Nov 5, 2012 | 7:18 PM
not sure but it wouldn't be just throwing the code only when idles if its from a valve. only ideas i can think of are the o2 sensors and the egr.
Old Nov 5, 2012 | 8:14 PM
MDTAHOE's Avatar
Professional Mechanic
You need to compression check it . O2 sensor or EGR will not cause a single cylinder misfire.
Old Nov 5, 2012 | 11:15 PM
last i checked about a month ago on compression it was all within 5-10 psi difference which is good which is why im leaning toward o2 sensors and egr cause at higher rpms they work harder.
Old Nov 6, 2012 | 5:55 AM
bdburb's Avatar
Could be intake gaskets. Was the plug out of #5 all gunked up with carbon or a whitish substance?
Old Nov 6, 2012 | 6:41 AM
MDTAHOE's Avatar
Again o2 and EGR will NOT cause a single cylinder misfire!
Old Nov 6, 2012 | 7:35 AM
kevinkpk's Avatar
What does the plug look like? Single cylinder misfire is something specific to that cylinder, i.e plug, injector.
