2000 chevy suburban 4x4 noise
Old Apr 21, 2013 | 9:41 PM
2000suburbanjeff's Avatar
Default 2000 chevy suburban 4x4 noise
hello I have a 2000 chevy suburban 4x4 1500.i keep hearing a noise at low speed like 5 to 10 mph it coming from the under my feet.anyone got any ideal as to what it could be?another question I went under while in park.am I spouse be able to turn the front drive shaft some?thanks jeff
Old Apr 21, 2013 | 9:48 PM
M800's Avatar
Could be your transfer case
Old Apr 21, 2013 | 10:14 PM
how do I go about testing the transfer case?
Old Apr 22, 2013 | 12:20 AM
M800's Avatar
Have you tried to shift it in and out of 4 wheel drive if it is bad it might make some noise when you do this or it might not shift into 4 wheel drive at all
Old Apr 22, 2013 | 1:59 AM
ya no problem at shifting into and outta 4x4 everything work as it should too.
Old Apr 22, 2013 | 8:20 AM
SWHouston's Avatar
When's the last time you did Fluid changes on your Differentials and Transfer Case ?
Are you just putting it in 4WD, or actually shifting into Lo Range ?
Old Apr 22, 2013 | 9:26 AM
M800's Avatar
Ok, it could be just starting to go bad or it could be that were the shaft goes into the transfer case it is getting wore just enough so that at slower speeds it wobbles but when at higher speeds its just fast enough to hold the shaft in one place, Other than taking it apart I don't think I no another way to check it
If it is not the transfer case you might want to check the oil in your transmission
Old Apr 22, 2013 | 11:29 AM
I have no clue i just bought from guy about a month ago myself.to be safe i'm gonna change all the fuild.i may let my auto guy check it.and yes i've run it threw all the gears seem to be ok to me.i also did figure 8s and stuff before i bought i didnt hear no noise.
Old Apr 24, 2013 | 10:44 PM
Question am I supposed be able turn the front drive shaft any at all?i can turn like 1/2 inch in each way.and that in park
technicauto
May 4, 2011 5:14 PM
dozer157
Jul 1, 2009 6:03 PM
chevyman1978
May 1, 2008 6:41 AM
rmoore1
Oct 14, 2007 1:57 AM
cowboyfromhell
Jun 5, 2007 9:31 AM
