2000 Tahoe Trailer Wiring Problems
Old Jul 5, 2010 | 2:26 PM
jbardwell's Avatar
Default 2000 Tahoe Trailer Wiring Problems
Everything works when headlights are not on, but when I turn headlights on and hit the brakes the trailer lights turn off? when headlights are on the flashers and lights work but when I hit the brake turns off trailer lights? It has the harness plugged into the factory hook up. Any help would be much appreciated!
Old Jul 5, 2010 | 3:56 PM
Verify that the vehicle harness is putting out the correct signals to all the pins, use this as a guide to what you should be seeing on each pin...
http://www.etrailer.com/faq-wiring.aspx
Old Jul 5, 2010 | 6:03 PM
LARIDERS's Avatar
kinda sounds like a bad ground. you will have to test truck and trailer grounds, that is where I would start. or you can just run new grounds.
intheknow
Jul 24, 2014 10:38 AM
mefref
Jul 12, 2014 6:07 PM
beninpa79
May 28, 2012 6:03 PM
jbardwell
Jul 5, 2010 2:50 PM
graves83
Aug 20, 2007 7:05 PM
