2002 Suburban 1500 Towing Question
I've just purchased a well maintained 2002 Suburban 2 WD with 5.3 motor 204,000 miles. If anyone can help with a couple questions? It has a tow capacity of 5000 pounds which is just at the weight of my travel trailer. I haven't hooked the Suburban to the trailer yet. If the powertrain can handle it, should it be able to tow this weight comfortably? Second question. It has a bumper hitch (receiver type) welded underneath and onto the bumper (but not the frame)- Should this be adequate or ....? Third question. Any issues, problems concerns before taking it on the road? Many, many, many thanks in advance.
You are at the towing limit of the rig. You should also use a weight distribution hitch and sway bars. Look that up. You can tow the trailer but the cooling system, transmission and engine need to be in top shape and have a clear trans cooler for cooling the trans fluid. Well maintained doesn't tell me anything. Proof? That receiver should not be welded to the bumper, PERIOD! Have it removed and install a quality receiver and attach to the frame, PERIOD! If you don't have the expertise to do that, have a tow shop help you.
I towed a 7,000-lb trailer with a 2001 1500. Logged about 10,000 miles, including Rocky Mountain passes.
To the OP - look under the back of your truck. Is the receiver simply attached to the bumper, or is it attached to a round bar which is then attached to the frame rails?
5000 should be fine for that truck. Do you know your gear ratio?
My 2001, at Powder River Pass, elev 9666'.
Highs: Plentiful power, quiet operation, smooth ride, big appetite for big jobs.
Towing goes from 8000 pounds for 4WD 1500-series models such as our test vehicle to 9700 pounds for a 2WD 2500-series. There are essentially two V-8s—a pair of 5.3-liters, one of them iron block, the other all aluminum—and two 6.0-liters, ditto, with variable valve timing on the aluminum version, a $1095 option included in our tester.
from car and driver magazine , it wouldn't let me copy the top of page
But anywhoos,
I drove over the road trucks for years so can tow above the rating with no problems, unless caught at the scales
LOL
and me gear ratio is 3.73 with G80 locker and 17" wheels and BF Goodrich KO2's
and my reciever is attatched to frame class 3 factory installed. My tr
ailer has axle brakes , and I know how to gear down on down grades, and how to brake early instead of waiting to last minute like many milinials do these days
But anywhoos,
LOLand me gear ratio is 3.73 with G80 locker and 17" wheels and BF Goodrich KO2's
But anywhoos,
LOL
But anywhoos,
Here the trailer tow ratings page from the 2007 owners manual. Please point out the 9,000-lb+ rating for your truck..With the 3.73,your actual tow rating is not more than 7200. But you make up for deficiencies in your truck with your extreme skill? How exactly does that improve the performance of your weak, semifloater rear axle?
did you actually read me post ? I know its rated as a half ton 1500, sorta figured that out when I saw it was a suburban 1500 LTZ on the Car lot before I bought it . I aint worried about the factory GVWR . I sorta mentioned that in me previous post that you Quoted . Now I don't recommend anyone do what I do , I stated that I have hundreds of thousands of miles ignoreing the GVWR
And Know how to still drive safely , unlike those who think its like living a SUV to the Mall .
And Know how to still drive safely , unlike those who think its like living a SUV to the Mall .Last edited by spunebil; Nov 27, 2020 at 1:20 PM.
And Know how to still drive safely , unlike those who think its like living a SUV to the Mall .Good luck with that, sparky. Have a nice day.
My mom is recently deceased, thanks for asking.
But maybe your wife might be up for the job, being as she's married to such a jackass?
