Old Jul 22, 2015, 11:01 AM
How-Tos on this Topic
Last edit by: IB Advertising
Print Wikipost
2003 tahoe squeals anytime..plz help..
Old Mar 12, 2011 | 9:52 PM
  #11
wowkita's Avatar
one more thing...it really comes randomly...i mean...
i changed the belt and it went away....and came back few month later..
and it disappeared for few month..i did'nt changed or do anything to the car.....and came back again....it's really making me crazy.....
Old Mar 12, 2011 | 10:00 PM
  #12
Default Drive Belt Squeal Diagnosis
Service Information
2003 Chevrolet Tahoe - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 669744
Diagnostic Aids
A loose or improper installation of a body, or suspension component, or other item(s) on the vehicle may cause the squeal noise.
If the squeal is intermittent, verify that it is not the accessory drive component(s) by varying their load(s), making sure they are operating to their maximum capacity. An overcharged air conditioning (A/C) system, a power steering system restriction or the incorrect fluid, or a failing generator are suggested items to inspect.
Test Description
The number(s) below refer to the step(s) in the diagnostic table.
The squeal may not be engine related. This step is to verify that the engine is making the noise. If the engine is not making the noise do not proceed further in this table
The squeal may be an internal engine noise. Remove the drive belt(s) and operate the engine for a few seconds, this will verify if the squealing noise is related to the drive belt(s) or an accessory drive component. With the drive belt(s) removed the water pump will not operate and the engine may overheat. Also diagnostic trouble codes (DTCs) may set when the engine is operated with the drive belt(s) removed.
This test is to verify that an accessory drive component(s) does not have a seized bearing. With the belt(s) removed, test the bearings in the accessory drive component(s) for smooth operation. Also test the accessory drive component(s) with the engine operating by varying the load on the accessory drive component(s) to verify that the component(s) is operating properly.
This test is to verify that the drive belt(s) tensioner(s) are not operating properly. If the drive belt tensioner(s) are not operating properly, proper belt tension may not be achieved to keep the drive belt(s) from slipping which could cause a squealing noise.
This test is to verify that the drive belt(s) is not too long, which would prevent the drive belt tensioner(s) from operating properly. Also if the incorrect length drive belt(s) was installed, it may not be routed correctly and may be turning an accessory drive component in the incorrect direction.
Misalignment of the accessory drive pulley(s) may be caused from improper mounting or incorrect installation of a accessory drive component, or the pulley may be bent inward or outward from a previous repair. Test for a misaligned pulley using a straight edge in the pulley grooves across two or three pulleys. If a misaligned pulley is found, refer to that accessory drive component for the proper removal and installation procedure for that pulley.
Inspect the accessory drive pulley(s) to verify that they are the correct diameter or width. Using a known good vehicle, compare the accessory drive pulleys.
Step
Action
Yes
No
Notice: Do not use belt dressing on the drive belt. Belt dressing causes the breakdown of the composition of the drive belt. Failure to follow this recommendation will damage the drive belt.
DEFINITION: The following items are indications of drive belt squeal:
• A loud screeching noise that is caused by a slipping drive belt(s) (this is unusual for a drive belt with multiple ribs)
• The squeal occurs when a heavy load is applied to the drive belt(s), such as an A/C compressor engagement, snapping the throttle, slipping on a seized pulley, or a faulty accessory drive component.
Did you review the Symptoms - Engine Mechanical diagnostic information, and perform the necessary inspections?
Go to Step 2
Go to Symptoms - Engine Mechanical
Verify that there is a squealing noise.
Does the engine make the squeal noise?
Go to Step 3
Go to Diagnostic Aids
Remove the drive belt(s). Refer to Drive Belt Replacement - Accessory or Air Conditioning Compressor Belt Replacement .
Operate the engine for no longer than 30 to 40 seconds.
Does the squealing noise still exist?
Go to Engine Noise on Start-Up, but Only Lasting a Few Seconds
Go to Step 4
Inspect for a seized accessory drive component bearing or a faulty accessory drive component.
Did you find and correct the condition?
Go to Step 9
Go to Step 5
Inspect the drive belt tensioner for proper operation. Refer to Drive Belt Tensioner Diagnosis .
Go to Step 9
Go to Step 6
Check for the correct length drive belt(s).
Go to Step 9
Go to Step 7
Inspect for a misaligned pulley.
Go to Step 9
Go to Step 8
Inspect for an incorrect size pulley.
Go to Step 9
Install the drive belt(s). Refer to Drive Belt Replacement - Accessory or Air Conditioning Compressor Belt Replacement .
Clear any codes.
Run the engine in order to verify the repair.
System OK
© 2011 General Motors Corporation. All rights reserved.
shayandude
Jun 4, 2022 4:10 AM
Big tiny
Jul 28, 2011 11:51 AM
skippybriggs
Jul 23, 2010 11:53 AM
MCF34
Aug 16, 2009 4:28 PM
givemeahollar
Astro
May 25, 2009 7:25 AM
