2007 Burb Front Hub Assembly Install
Old May 28, 2013 | 9:58 PM
coach torres's Avatar
Default 2007 Burb Front Hub Assembly Install
Fellas, thought I'd pass on some info. I found the issue with my wife's Burb. Front LH hub assembly gone bad. The replacement was a heckuva lot easier than I had originally anticipated (I've got pics if anyone is interested). I did however encounter a problem after the install. The "service traction control" and "abs" indicators are now showing. I disconnected the negative battery cable in the hopes that a reset/relearn would take place....no luck. I checked the sensor's connection from the hub assembly and it appears to be firmly connected. Any ideas or advice? Thanks in advance.
Attached Thumbnails 2007 Burb Front Hub Assembly Install-burb1.jpg   2007 Burb Front Hub Assembly Install-burb2.jpg   2007 Burb Front Hub Assembly Install-burb3.jpg
Old May 29, 2013 | 6:35 PM
The "service stabilitrak", "service traction control", and "abs" issue has been resolved. I connected the old hub assembly speed/abs sensor back up to harness and notification disappeared. My local O'RAP manager has ordered a new sensor(free of charge) to replace the one on the new hub assembly. Worst case scenario is having to put the "old" speed/abs sensor on the new hub.
Old May 30, 2013 | 8:01 PM
The issue with the service stabilitrak, traction control and ABS indicators has finally been resolved. I put a new wheel/abs sensor in this afternoon and still had warnings popping up on dash display. I hooked the old one back up and it removed the warnings. I figured I would just put the old sensor on the new hub and all would be well. As I removed the old sensor I noticed there was no oval shaped washer like the new one had. So I simply removed the washer from the new sensor and put back together without washer. NO MORE WARNING LIGHT>>>SERVICE STABILITRAK>>>>SERVICE TRACTION CONTROL>>>>>AND NO MORE>>>>ABS LIGHTS ON. Can someone with some expertise in this area please explain why a washer would cause that?
Attached Thumbnails 2007 Burb Front Hub Assembly Install-wheel-abs-sensor.jpg   2007 Burb Front Hub Assembly Install-wheel-abs-sensor1.jpg
gmlover
Mar 26, 2012 1:20 PM
jrsavoie
Apr 15, 2010 10:58 AM
jwko
Dec 12, 2008 9:33 PM
