2007 Suburban Dead battery
Old Nov 18, 2007 | 11:07 AM
Rescue30's Avatar
Default 2007 Suburban Dead battery
Car wasn't used a whole day Saturday from Friday 6pm, went for a few small drives last night not more than 10 minutes each , this morning it was DEAD !, I have emergency lights and sirens installed and the amp draw after shutdown is from 0.136-0.101, is this enough to kill the battery , after how many hours ? The lights have been installed for 3 months and have never given me any problems Should I go with Optima battery ? The red or the yellowone ?
Thanks
Old Nov 18, 2007 | 5:52 PM
Default RE: 2007 Suburban Dead battery
I'd have the battery and charging system checked first. Advance Auto and others will do it free.
Old Nov 18, 2007 | 11:44 PM
engine2's Avatar
Yellow top is best for your kind of set up. You may also want to put a on/off power disconnect switch to your emergency equipment (that way you can kill any power consumption to your emergeny equip at the flick of a switch). LED lights draw the least amount of current if you did not know that already. I would like to see of pic of you setup. Good Luck - Engine 2
Old Nov 19, 2007 | 7:51 AM
Rescue30's Avatar
My Buddy tetsed it , under load it's 10.0 , but the car is only 5 months old ,can the battery be bad ? I'm sure the delaer is going to blame it on all my "accessories" I think i'll just get an Optima , does anyone know which is the biggest Optima that will fit in the susburban ?Engine 2 i'll send you a link by PM
Old Nov 19, 2007 | 8:04 AM
agtkgv's Avatar
There is a battery drain down recall on 07 Subs. Not sure if it is on all, but I know it was on 2500's. Check with your dealer... It's a computer flash I believe.
Old Nov 19, 2007 | 6:26 PM
Rescue30's Avatar
My Suburban was built in June 2007, I thought that was after the batteryupdate issue ??
Old Nov 19, 2007 | 7:58 PM
admmck's Avatar
Just had my 2007 Tahoein the shop this morning to have the tires balanced, and they updated the computer due to the battery drain issue it was causing.
Old Nov 19, 2007 | 8:12 PM
red's Avatar
red
Learned from experience........the battery will drain dead with the key left in the ignition, even if turned all the wayto OFF / LOCK.
Old Nov 21, 2007 | 6:49 PM
bobbyt's Avatar
Just got my tahoe back needed new battery even after ecu battery draining upgrade for some reason in some 07 tahoes batterys go dead over night in the cold.
Old Nov 21, 2007 | 7:29 PM
Didn't they tell you that you have to keep it in a nice warm garage?
Glad you got it fixed.
