2007 Tahoe No Crank
Old Oct 25, 2011 | 7:45 PM
  #11
kevinkpk's Avatar
Originally Posted by rnorman4
The bill says: U0140 code set, no comms with BCM. I attached the technicians troubleshooting etc... if anyone's interested.
I plugged in my small tester before bringing the Hoe to the garage (innova 3100) and it didn't show any DTC's in the computer. Is this normal? Should that little scanner pickup that code?
I got the truck back (they tried to charge me $1300 but I threw a fit like a b**ch and told them I was going to loose it on the service manager when I came in so they knocked off several hours of service and dropped the price of the new BCM back to $380 so I got charged $730 which is still wayyy too much in my opinion). Apparently it took over 3 hours just to find the problem, and I'm not sure how many more to fix it, even though the U0140 code is stated on the receipt.
In any case I just bought a used Pontiac Vibe today in case the Hoe decides to die again for no reason. Got the vibe cheap because it's badged GM, but I understand most of the guts are Toyota thankfully, (which is the angle the sales guy was using to get the most $$ for it).
Well, use this one they "fixed" as a trade in, surely they can't refuse......
Old Mar 12, 2017 | 12:51 AM
  #12
Grace Covarrubias's Avatar
Default We're having the same problem with our Chevy Tahoe 2007.
Same description as original message most things light up, but door locks don't work, battery voltage is at zero and Tahoe won't crank. We are going to order the BCM and switch it out. Hopefully, that works for us as well. We will post update on results.
Old Apr 14, 2018 | 12:54 PM
  #13
Michael O'Neill's Avatar
Hi Grace, did the BCM fix your problem? Everything on my Tahoe seems to work fine but won’t crank. I can bypass the relay and make the engine turn over but it will not start. Thanks!
Old Apr 14, 2018 | 2:07 PM
  #14
Hi Michael,
Yes, it did. We ordered the BCM and then had the dealer install it. It was way cheaper than having them order the part for us.
Best of luck!
Old Apr 14, 2018 | 2:12 PM
  #15
Thank you!
Old Apr 14, 2018 | 2:13 PM
  #16
No problem!
Old Nov 19, 2019 | 3:05 PM
  #17
Antwyonne Murray's Avatar
Default Bcm
Ok so I have the same problem and I got the bcm put in and still no crank no start
Old Feb 28, 2020 | 10:13 PM
  #18
Nick Decker's Avatar
did you ever figure out your issue
ctlawless
2007 - 2013 (GMT900)
61
Apr 4, 2024 1:54 PM
Jeff Hawkins
Aug 19, 2022 5:15 PM
eikonaws
Sep 21, 2013 3:03 PM
lynchcrew
Nov 17, 2012 7:34 PM
