2007 Tahoe Rear Air Module Lighting
Old Jan 15, 2013 | 12:46 PM
bushler's Avatar
Default 2007 Tahoe Rear Air Module Lighting
Hi All,
I am new to this forum. I have been looking over some posts and could not find the answer to my issue. I recently purchases a 2007 Tahoe LT.
The rear air and entertainment console buttons do not illuminate. The screen where is shows the temperature and that the heated seats are on does. The temperature buttons and the fan speed and the heated seat buttons do not light up when it is dark.
I tried turning the light dimmer but it was already all the way up. I believe the part number might be 15881861 or 15886277. These may be interchangeable but not positive.
My question is, do the rear module buttons illuminate? I was going to buy this module but the guy at the local dealer told me that his tech said those do not light. My research concluded when I looked in a 2008 Suburban LT and the rear buttons illuminated.
Any help would be appreciated.
Thanks,
Brian
Old Jan 15, 2013 | 2:46 PM
Welcome to the forum...
I thought the did lite up , how else would the passengers adjust them right?
I'll check this evening and report back if no one else does...
Old Jan 15, 2013 | 6:59 PM
bushler's Avatar
I appreciate it. I am just confused cause the service writer was told by a tech they didn't. Does not seem right that they wouldn't.
Old Jan 15, 2013 | 7:09 PM
Here is what mine on my 2007 look like, just took it mere minutes ago...
Attached Thumbnails 2007 Tahoe Rear Air Module Lighting-img_20130115_190443.jpg
Old Jan 15, 2013 | 7:35 PM
bushler's Avatar
Must be a bad unit in mine then. Do you know how to change out the unit? Any pointers on where to start disassembling?
Thanks for checking on this for me!
Old Jan 15, 2013 | 7:53 PM
I would try pulling it out and check the connections...
IF you can open the unit I'd check for replaceable lamps, but Id be my guess that the whole unit needs to be replaced...
You can check GM parts direct for the part...
Old Jan 16, 2013 | 9:45 AM
bushler's Avatar
Thanks for the help! I appreciate the quick responses.
I picked up a new modules on ebay for $90. We'll see how it works out.
Thanks,
Brian
Old Jan 16, 2013 | 10:15 AM
Good to hear :-) take and post a few pictures of the process if you can.
Old Jan 16, 2013 | 10:26 AM
bushler's Avatar
Will do. I posted another post about my windshielf wipers and passenger mirror if you have any insight into it it would be appreciated.
bushler
Jul 17, 2020 2:05 PM
pjm333
Aug 19, 2015 3:40 PM
IncisionInd
Sep 12, 2009 11:13 PM
jzlharvey
Dec 28, 2007 10:35 PM
superdaveidaho
Nov 13, 2007 5:31 PM
