2008 Suburban 1500 sway bar mount tore out of the frame
Old Nov 12, 2018 | 8:44 PM
  #31
Hi-psi's Avatar
Originally Posted by James Kent
I am currently going through the same thing mentioned in this post. My sway bar mount has broken free from rust.
Just get the ones that are actually made by GM for like $16 ea.
Part #'s above.
Install guide:
https://gm.oemdtc.com/6392/clunking-...-chevrolet-gmc
Old Nov 14, 2018 | 7:11 AM
  #32
SERVICE@PAS's Avatar
Rikyk
please let me know if i could buy a set of bracket for sway bar
i have a 2008 cadillac escalade .
Thanks kevin ( service @premiereautosport.com)
Old Apr 7, 2019 | 2:15 PM
  #33
Toxic Masculinity's Avatar
How much for this?
Originally Posted by RickyK
Old Apr 11, 2019 | 1:31 PM
  #34
Nevadaman's Avatar
Damn that sucks. You did a good job at repairing it. Rust sucks.
I'm so glad my 2004 has no rust or corrosion. I just did my shocks and axle and didnt even need PB blaster on the bolts. Came off easy.
Old Jun 13, 2019 | 3:49 PM
  #35
JaMiN - Jack of all Master in None's Avatar
Default Complaints?
I'm having the same issue with mine. A good site that was providing information on how to repair these issues just got a cease and desist letter from GM. They are well aware of this issue and even have parts to replace the mounts. I say start filling complaints with the NTHS. This absurd.
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
Old Jun 13, 2019 | 3:51 PM
  #36
Part #'s above.
Install guide:
That site just got shut down unfortunately.
Old Nov 27, 2019 | 5:23 PM
  #37
Jeffery Larkowski's Avatar
Default mounts
Mount broke off on my 2008 gmc yukon passenger side front sway bar. Does your mount fit this??
Old Aug 5, 2021 | 10:20 AM
  #38
bugzimalone's Avatar
Originally Posted by djacobs5179
The sway bar is bolted to a piece that stick out from the frame thats welded on. I am not sure why this has happened. The drivers side of my car is fine and the passanger side is destroyed. I am wondering how the rust happened. Maybe it has to do with the type of metal uses for the bolt that holds it in place?
my sub went bad on the passenger side only. I noticed a lot of water / condensation pouring down directly on that bracket thereby rotting it out.
im making a mount and welding the original clamp and rubber back into the truck.
Old Aug 18, 2021 | 8:41 AM
  #39
prinzlmeisl's Avatar
Default Same issue on my 2011 Yukon Denali
There is a service bulletin (15-NA-082) that I attached, as some of the links that others provided no longer work. It lists the part numbers.
I just ordered the right bracket. My local GMC dealer clearly did not want to deal with this and the service advisor made up a story about having the replace the frame, parts not available, and that I should go somewhere else and have it welded. Sad.
The problem is clearly caused by the A/C condensate drain being right in front of the mount, with water dripping on it all the time.
File Type: pdf
stilllearning6
Apr 23, 2021 6:09 AM
Tom Colson
Dec 19, 2020 10:20 AM
AustinB
Aug 18, 2020 1:15 AM
curtis1512
Dec 11, 2017 10:02 AM
RockVegas
Aug 31, 2013 5:08 PM
