2009 Chevy Suburban HVAC control
Old Jun 3, 2013 | 7:08 PM
supermixer's Avatar
Default 2009 Chevy Suburban HVAC control
Hey everyone
I'm new to the forum so forgive me if this question has already been answered.
My current hvac control unit has a couple of buttons that are worn so doing a search online I found the correct replacement unit which i've purchased.
My Hvac control unit controls dual air on the driver , passenger and rear.
it also has an "auto" button for auto climate control which i use quite often
When I remove the existing hvac unit and plug up the replacement, will this work or does this control unit require programming? if it requires programming, does anyone here or can anyone point me to a site that provides steps on how to do this? The dealer wants $100 to program and $100 to install it. Rather than fork out $200, I would like to try this myself
any thoughts would be greatly appreciated.
thanks
Jamie
Old Jun 3, 2013 | 9:32 PM
Welcome to the forum.
I believe that this part requires dealer programming. Others may know for sure.
Old Jun 4, 2013 | 8:04 AM
supermixer's Avatar
dang it .. that's what I thought .. I couldn't find anything online after about 30 minutes of searching lol ..
Old Jun 4, 2013 | 9:20 AM
I would suggest installing it and then taking it in for the programming, might try planning it around scheduled maintenance like an oil, filter change tire rotation at the dealer and they may just throw the programming in for free or reduced charge....
Old Sep 13, 2013 | 8:37 PM
riggz's Avatar
Sorry to dig up an old thread but my 2009 Suburban has this issue and I found a website controlbuttonrenu.com that sells replacement buttons. Has anyone used their buttons? I can't find any pictures of their actual products.
Old Sep 14, 2013 | 8:21 AM
supermixer's Avatar
Interesting site that you found. I think the easiest way without any hassle to you would be to replace the hvac module. (
Amazon.com: ACDelco 15-74023 GM Original Equipment HVAC Control Panel: Automotive Amazon.com: ACDelco 15-74023 GM Original Equipment HVAC Control Panel: Automotive
) Its not too expensive. I found one on amazon for about $131 brand new. Take it to your local chevy dealer and have them put it in as it will also require programming. I saved about $100 from buying this part at the dealer and sometimes you can get them to cut their labor charge in half
hope this helps you.
Old Sep 14, 2013 | 1:48 PM
riggz's Avatar
I have no problem taking things out and fixing them if it saves me $100+.
Old Oct 1, 2013 | 9:50 PM
It never cease to amaze me what can be found on Amazon I remember when they started out only selling books...
Old Oct 2, 2013 | 8:14 PM
trainwreck91's Avatar
not a bad deal on that site and it says it takes 10 min to change the buttons
samyar
Aug 2, 2015 10:16 PM
JAMES.PELLEGRINI
Mar 22, 2012 10:49 AM
Chredw
Dec 5, 2011 6:02 PM
dlm43230
Nov 7, 2010 1:55 PM
pinch
Feb 7, 2010 5:09 AM
