2013 Tahoe TPMS showing crazy
Old Dec 3, 2017 | 6:43 AM
shirazy747's Avatar
Default 2013 Tahoe TPMS showing crazy
Hi,
After switching front rare tires off ring 5 months ago since then I keep seeing " SERVICE TIRE MONITOR SYSTEM ",
I have done " Relearn Tire position " reset and it was ok only for a day , then "Service Tire Monitor Sys. " warning came back on again.
Help please
Old Dec 3, 2017 | 11:12 AM
explain what "switching front rare tires off ring " means
Old Dec 6, 2017 | 1:36 PM
shirazy747's Avatar
Dear tech2,
1-I took the tire out of the ring and turned it opposite and put back(The side of the tire toward the engine now is outward),
2-besides I moved the rare tires to front and vice versa,
3- after a few minutes i saw " SERVICE TIRE MONITOR SYSTEM ", warning ,
4- I did Relearn Tire position reset by checklist , it was ok for a couple of hours ,but the warning came back again , I did this 2 times but the warning is back again.
the warning is not going out,
Old Dec 6, 2017 | 7:08 PM
Suburban Dude's Avatar
Are the tire sensors from the original truck or are they older?
SD
Old Dec 7, 2017 | 2:25 AM
shirazy747's Avatar
The sensors are the original and have never changed them
Old Dec 7, 2017 | 8:09 PM
so you removed the tire from the rim and, spun it around and mounted it back on the rim. what equipment did you use to remove the tire from the rim?
If that's all you did, you must have damaged the sensor in the process.
Old Dec 8, 2017 | 10:16 AM
shirazy747's Avatar
Hi dear,
I didn't actually do anything , a mechanic did it , it IS possible for the sensor(s) to be damaged, but there is something odd going on= When Front Left tire is deflated Rare Right tire low pressure warning comes on for a short while , Therefore I imagine sensors must be working fine, aren't they sir?
Old Dec 9, 2017 | 9:28 AM
Looks like they didn’t keep things organized and moved the rims around. I recommend you go through the reset procedure again. The reset procedure I used required doing a small deflation at each corner until the horn honked. The procedure is on You Tube.
Also, each TPMS sensor has a battery. Four years is not much time. One sensor died after 8 years on my 2008 Burb but I heard the mechanic say they sometimes go earlier.
You can get new sensors off EBay or Amazon much cheaper than the Chevy dealer.
SB
Old Dec 9, 2017 | 9:51 AM
I'm probably about to jinx myself, but my 07 with 130k at nearly 11 yo still has original TPMS batteries... and only the second set of tires rotate those babies regularly
Old Dec 10, 2017 | 11:19 AM
shirazy747's Avatar
Dear DUDE ,
1-Yes I agree on "Looks like they didn’t keep things organized and moved the rims around" and might have damaged sensors,
2- I have done the reset procedure twice and I will do it again sir .Yes I did the youtube thing it required 8-10 second deflation, no horn honk or chime sound but reset worked fine for a couple of hours, then warning back again.
3- I am going to check the sensor batteries ( I don't know where they are located though) but I think they're easy to find .
I will inform you of the results sir
I live in Iran!! No American company or related services are allowed here, I bought Chevy (from Dubay) because I love it ( I had a GMC when I was a student in Texas, I don't like Europian or East Asian cars, TAHOE is the king of road and off road) besides we can not own Visa or Maser cards here to buy anything from Amazone or Ebay or the Chevy dealers as well.And THEY do not accept BITCOINS( I have some ) I have to suffer!!
I really appreciate your patience and help sir
