2015 Stabilitrak problems
Old Oct 20, 2023 | 12:09 PM
  #41
@BlaineBug Is she getting a stabilitrak warning?
Old Oct 20, 2023 | 12:11 PM
  #42
BlaineBug's Avatar
Tonight was a very close call. The truck ripped the steering wheel out of my hand and truck shut off briefly
See refenced TSBs, especially 18-NA-161.
Old Oct 20, 2023 | 1:02 PM
  #43
I heard you the first time. If she doesn't have stabilitrak symptoms then this is the wrong topic.
Old Oct 20, 2023 | 3:33 PM
  #44
BlaineBug's Avatar
Please don't be so salty - I believe I was instrumental in the creation of TSB 20-NA-212 which I do not believe it related to her concerns posted here recently. No one had really ever experienced the issue I was describing in great detail as I perused the internet and posted about it on various forums. So if I have something helpful to provide I'll do so, which is a lot more helpful than telling someone to post a new thread about it - who cares.
However I do believe TSB 18-NA-161 does in fact directly relate to her steering jerks - her vehicle is a 2015 as well which is very early build, just in the timeframe where a lot of owners with 2014-2015/2016 model year Silverados and Sierras experienced the same issue with Ground #G218 being pinched between the firewall or top of dash and some sort of an insulation pad.
As for her loss of brakes it is possible the vacuum pump is to blame, as I also heard some of the early build vacuum pumps were quick to require replacement! Service Bulletin PIT5361 also outlines this braking problem - take a look here, and 2015 Tahoe is also part of the affected vehicles! https://static.nhtsa.gov/odi/tsbs/20...57667-3895.pdf
Now all she has to do is print out the 2 TSB's and 1 Service Bulletin and take them to a mechanic of her choice, and describe the issues, and I believe we'll find that there may be two "coincidental" yet separate issues occuring at the same time. UNLESS the ground wire mentioned in TSB 18-NA-161 also affects braking performance somehow.
Old Oct 20, 2023 | 8:25 PM
  #45
Nobody is salty. I'm trying to get this car owner the best help possible, and I think the best way is for her to post a dedicated topic, instead of getting buried in this unrelated one.
Old Nov 2, 2023 | 12:23 PM
  #46
BlaineBug's Avatar
If you or anyone else wishes to avoid the tips and recommendations I have made regarding such a problem, that's up to the end-user, and I won't sweat about it.
klondike
18
Sep 24, 2020 10:23 PM
tiggerbad71
Jul 17, 2017 11:53 AM
dcparks1
Jun 3, 2016 3:25 PM
ldelben15
May 15, 2015 12:31 PM
rbarry0930
May 6, 2015 5:35 PM
