2015 Tahoe PPV Brakes squeaking
Old June 6th, 2016, 7:22 AM
  #31
clarke704's Avatar
I have (4) four 2015 Tahoe PPV's----all of them came from the dealer new and had the exact same brake issues, squealing/noisy etc.... and yes the dealer cannot find anything wrong as well. The 2015 has issues!!!! We have put on GM and raybestos "police" rotors and brake pads----we are lucky to get 15k miles from them. UGGGGGGGGGGGGGGGGGGGGG
Old June 6th, 2016, 8:01 AM
  #32
squeaking front or rear or both?
Non ppv use organic linings. these pads have a better brake feel and are less likely to squeak....however they will fade under extreme use so are not rated for ppv. It may suck but you its a trade off for the performance the part needs to have. Engineering design is a trade off sometimes.
I have seen some updated products for other vehicles have chamfers in the linings to reduced squeal....maybe they will update the design for this also.
Old June 6th, 2016, 8:08 AM
  #33
Originally Posted by SabrToothSqrl
I've seen a lot of newer cars that pull the pads away from the rotor.. saves brake wear and helps MPG.
they use a quick take up master cylinders...gm was one of the first companies to use this design 20 years ago.
Old November 5th, 2016, 7:33 PM
  #34
Ben Sims's Avatar
Default 2015 Suburban with squeaking brakes
My suburban is doing the same thing. Did you ever figure out how to fix it. I have had pads and rotors replaced with no luck getting rid of the squeak. Can't see to find anyone that knows the fix.
Ben.
Old November 5th, 2016, 11:34 PM
  #35
change the pads. once they are overheated the pads will always squeal. try a different lining material.
Old September 10th, 2017, 3:59 PM
  #36
Amy Dobrikova's Avatar
Intelligent Fleet solutions has worked with several fleets that have this same issue, we currently have a solution. Please contact me at adobrikova@intelligent-fleet.com. Thank you, Amy
Chevrolet Forum News
February 14th, 2014 4:08 PM
RMB 97 TAHOE PPV
January 13th, 2013 6:16 AM
ambiguous216
November 26th, 2011 7:24 AM
KiDD QuE
June 18th, 2011 9:41 PM
84_LS1_Supra
August 16th, 2009 4:36 PM
Quick Reply: 2015 Tahoe PPV Brakes squeaking
