2021 Tahoe - Need to find a switched fuse to use for a Dashcam
Old Jan 22, 2023 | 7:39 AM
  #11
repairman54's Avatar
Body control module controls those lights. Shop manual with wiring diagrams is a must have when you are hacking into the system. It's too easy to blow up expensive parts. alldatadiy.com is what I use for my fleet.
Old Jan 24, 2023 | 4:43 PM
  #12
Sweesym77's Avatar
Aw man...I totally cave manned some stuff to achieve a switched 12v power plug inside my old Suburban. ***because non of them are switched!!!***
(1) I found the fuse that runs to the power outlets (unswitched).
(2) Then I found a switched fuze to tap into.
(3) Broke one of the tangs off of the fuze running to the power outlets. (on the supply side)
(4) Ran a jumper wire from a switched fuze to the one tang left on my fuze for outlets
Viola...my 12v outlet plugs are now switched on and off with ignition swich...(I may have caused other electrical problems)
*****do this madness at your own risk***
Old Apr 5, 2024 | 12:27 PM
  #13
JeremyLaurenson's Avatar
Where did you guys ground to?
Old Apr 5, 2024 | 1:04 PM
  #14
you can ground to any bolt or bare metal on the body
Old Apr 23, 2024 | 6:58 PM
  #15
Bpharis's Avatar
Originally Posted by Baz
For those who are looking for this in the future, I used a Micro3 fuse tap in the passenger fuse box on the fuse F26 USB/SEO RAP.
Turns on and off with the car.
I used this fuse with a fuse tap for a rear entertainment system , works great as in comes on with the car and goes off with the car BUT I also lose power when I open the driver door or rear driver side door, any thoughts??
Old Dec 22, 2024 | 5:01 AM
  #16
Dmz's Avatar
Dmz
Newly Registered
I used F26 USB/SEO RAP but it switches off & on when the car comes out of autostart on a 2021 suburban. It reboots the camera so interrupts recording at traffic lights. I don't want to disable autostart. Has anyone found a better fuse for a switched circuit?
Cool Beans
Sep 21, 2020 11:54 AM
trund
Sep 18, 2020 9:25 AM
Christopher Krumholt
May 17, 2013 6:10 AM
KurishaT
Cobalt
Oct 9, 2012 8:12 PM
tunneyc
Uplander
Jul 16, 2011 2:18 PM
