Brake lights missing (brake lamp relay completely gone?) 97 tahoe 5.7
Old Dec 2, 2021 | 1:16 PM
laurensantillanes's Avatar
Default Brake lights missing (brake lamp relay completely gone?) 97 tahoe 5.7
Hello i have an issue that my 3 brake lights do not work. I have tail lights, and hazards working but nothing occurs when i hit the brake pedal. I went to get a brake lamp relay for the fuse box because i looked and it was missing? But there is absolutely no connectors there to click the relay into ? I also replaced fuse 1 inside the vehicle.
i just bought this vehicle for next to nothing for a winter beater
if anyone knows if theres anything else i should look at or do i have to buy a whole fuse box?
Pictures included
Old Dec 2, 2021 | 1:40 PM
Rednucleus's Avatar
Do your hazards work? Notice the 30a stop/haz is missing bottom right of your pic
Old Dec 2, 2021 | 2:01 PM
yes they do ! That's why it is throwing me for a loop. They are after market lights if that makes a difference, the hazards, running lights and reverse lights all work just not the brake lights (all 3)
Old Sep 24, 2023 | 7:27 AM
jairod's Avatar
Default We're you able to fix your issue?
Pictures included
We're you able to fix your issue? Lmk please cause I’m running in the same issue
Old Sep 24, 2023 | 7:37 AM
hanky's Avatar
Did you check to make sure there is or is not power getting to the stoplight switch?
Old Sep 24, 2023 | 8:27 AM
honestly no the rear end fell of the truck a few months later and I sold it but good luck !
Old Dec 2, 2024 | 9:32 PM
RedZebra's Avatar
The brake light engagement is coupled with the buzzer fuse, inside cab fuse box, upper corner is a 15 amp fuse. Check it. That's what my problem was
Old Dec 3, 2024 | 9:23 AM
Cusser's Avatar
Check brake light switch at the pedal.
PatrykKoul
Apr 26, 2023 9:14 AM
Kdwoods80
Dec 4, 2021 8:21 AM
Sassynana
Cobalt
Dec 15, 2017 5:03 PM
Skyking
Jul 9, 2012 6:12 PM
Antonia
14
Jun 18, 2011 8:33 PM
