A/C is really cold only at low fan speed
Old Aug 3, 2021 | 9:07 AM
  #11
kmcv2's Avatar
How's about when at the setting just below the high setting? Still the same no cooling effect?
Still no cooling effect. Mine cools good at 4 clicks from the bottom. On an automatic climate control unit.
Old Aug 4, 2021 | 4:50 AM
  #12
oilcanhenry's Avatar
Starting to think this COULD be an ECM issue. You'd think the fan blower wouldn't affect the A/C system, but most likely it does nowadays. Seems like the ECM is tied into everything. I'll still search for an answer, as I am adept at A./C systems and need to know everything about them.
Edit: it may be a relay issue. Also, do your engine cooling fans work when this occurs?
Old Aug 4, 2021 | 8:27 AM
  #13
hanky's Avatar
From the gauge readings you submitted, I also question the amount of refrigerant you added.
To me ,and I could be wrong, I think you may have either an overcharge of refrigerant or the compressor may be getting tired.
Old Aug 6, 2021 | 8:00 PM
  #14
I think it's an ECM, a bad sensor, or a resistor issue, but I could easily be mistaken. OP said he put in a new compressor, accumulator and orifice tube, so unless one of those was manufactured incorrectly I think this is an electrical issue of some kind.
trund
Jul 15, 2021 9:29 AM
David DSa
Sep 6, 2018 5:15 PM
JUNIOR
Sep 6, 2015 2:54 PM
cgee
Sep 5, 2013 2:48 PM
gregory305
Dec 16, 2012 6:20 PM
