Old Jul 29, 2015, 12:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Change Engine Oil indicator
Old Oct 28, 2007 | 3:57 PM
jntmless's Avatar
Default Change Engine Oil indicator
OK - I changed the oil in a 2002 suburban, but I'm having trouble resetting the "change engine oil" light. I've tried the 3 presses on the accelerator pedal thing(many times, with variations). Is there something I'm missing? This is a bit frustrating! Any help will be greatly appreciated. Thanks.
Tom
Old Oct 30, 2007 | 1:07 PM
ZX1100F1's Avatar
Default RE: Change Engine Oil indicator
Turn key to full on but do not start engine then immediately press and release the accelerator pedal completely 3 times within a 5 second total interval.
Old Nov 13, 2007 | 7:03 PM
johnboy's Avatar
Turn key to on position....do not start the internal combustion engine.. pump gas peddle 3x quickly turn key off ...that wil ldo it . goood luck
Old Nov 14, 2007 | 1:24 PM
ZX1100F1's Avatar
ORIGINAL: johnboy
You waited two weeks to post the exact same thing that I did??????
Good job!
Old Nov 19, 2007 | 6:55 PM
Rivernut's Avatar
What year did this feature show up?
Old Nov 23, 2007 | 5:11 PM
johnboy's Avatar
In reply to mr/mrs. xz1100f1 this person said I replied exactly ashe did ,my 1st grade child saw that my response was different than his! this guyis asbright as a 3 watt light bulb!!! YOU MUST TURN THE KEY OFF!!!
Old Nov 23, 2007 | 5:18 PM
DAVID L. PAUL's Avatar
OK CHILDREN
Old Nov 23, 2007 | 6:21 PM
johnboy's Avatar
This child was just trying to help a fellow "BURB" owner!!
Old Nov 23, 2007 | 7:21 PM
I KNOW THAT'S WHAT MOST OF US ARE HERE FOR . JUST HAD TO GOUGE A LITTLE
Old Nov 23, 2007 | 7:36 PM
johnboy's Avatar
A little fun goes a long way thanks from Johnboy
ticu
Uplander
11
Oct 13, 2009 8:00 AM
Brian@work
Apr 24, 2009 6:23 AM
Twobitt
Aug 15, 2007 12:25 PM
larry_chip
Apr 24, 2007 11:46 AM
digdug
Feb 4, 2007 3:08 PM
