cig lighter pops fuse in gps car charger
Old Sep 18, 2020 | 5:45 PM
Cool Beans's Avatar
Default cig lighter pops fuse in gps car charger
Greetings. Don't smoke so never use the lighter accessory. Garmin gps not working. Looked at 2 amp fuse inside gps charger plug-in and it was popped. Got new fuse in and tried again. Fuse pops. Another fuse in and tried in other two Tahoe lighters. Both worked and did not pop fuse.
Looked inside suspect accessory and see that it is missing a round plastic insert way in the back. Probably 1/8 inch thick and looks like a hose washer. Probably this is the reason fuse pops.
Any thoughts as to what exactly this part might be....or do I pry one out of the back seat lighter and use it. (I am a auto dunce. Will I short something out and cause a problem )? I can probably find the fuse under the hood or under dash and remove it, before my attempt.
Any help is appreciated.
Old Sep 18, 2020 | 6:01 PM
kevinkpk's Avatar
Problem in the socket, you should be able to replace it.
Old Sep 18, 2020 | 11:00 PM
Dorman makes replacement cig sockets.
Old Sep 19, 2020 | 7:16 AM
All the auto parts stores sell replacement sockets and they are fairly cheap.
Old Sep 20, 2020 | 11:12 AM
Amazon Amazon
https://www.homedepot.com/p/Lighter-...7450/311347832
Old Sep 21, 2020 | 8:37 AM
Cool Beans's Avatar
Hi and thanks for the replies. I am an automotive dunce and handyman dunce. So....I will go to the local Chev dealer and get the OEM part or parts.......and go to nearby auto shop that I have used for years and have them install.
Old Sep 21, 2020 | 9:55 AM
You will pay a lot more at the dealer for parts than necessary. Installation is easy and will also cost a lot.
Old Sep 21, 2020 | 11:54 AM
The shop will get the parts at wholesale rate
trund
Sep 18, 2020 9:25 AM
Chevyman06
Nov 14, 2015 4:45 PM
Christopher Krumholt
May 17, 2013 6:10 AM
tunneyc
Uplander
Jul 16, 2011 2:18 PM
Stephsr
Jan 21, 2008 10:36 PM
