Clunk in the front end when starting from a stop
Old September 3rd, 2012, 9:46 PM
dkfire44's Avatar
Default Clunk in the front end when starting from a stop
My 2006 suburban has developed a slight "clunk" when taking off from a dead stop, it does not do it from a rolling stop or if a take off really slow. Any ideas at what I could look at?
Old September 3rd, 2012, 11:57 PM
Welcome to the forum.
First guess would be U-joints. Try shifting from Drive to Reverse and back w/ the brakes on.
Second would be something in the suspension.
Old September 4th, 2012, 12:10 AM
dkfire44's Avatar
Will I hear the noise in the u joint when I go fron drive to reverse? Because no I only hear it when I take off from a stop
Old September 4th, 2012, 12:21 AM
If there is excessive play in the U-joints, you can hear/feel it when reversing the drive shaft to take up the slop.
Old September 4th, 2012, 11:18 AM
Another possibility is greasing the yoke on the driveshaft. These trucks have a tendency to do this. Greasing the slip joint solved my problem.
Old September 5th, 2012, 12:11 PM
spyncycle's Avatar
Check the shock mount bolts at top and bottom.
Old September 6th, 2012, 10:12 AM
SWHouston's Avatar
I'd take a look at the Upper Control Arm Bushings... all 4
Old September 7th, 2012, 9:26 AM
Official GM Rep
Any luck getting this resolved since your last post, dkfire44?
Sarah (Assisting Louis), Chevrolet Customer Service
timabrams
Uplander
December 7th, 2011 4:11 PM
lumina38
June 24th, 2011 12:32 AM
fsh4fun05
May 1st, 2009 11:22 AM
Gypsy
April 8th, 2008 9:56 PM
Quick Reply: Clunk in the front end when starting from a stop
