Clunk in the front end when starting from a stop
Old Sep 3, 2012 | 9:46 PM
dkfire44's Avatar
Default Clunk in the front end when starting from a stop
My 2006 suburban has developed a slight "clunk" when taking off from a dead stop, it does not do it from a rolling stop or if a take off really slow. Any ideas at what I could look at?
Old Sep 3, 2012 | 11:57 PM
Welcome to the forum.
First guess would be U-joints. Try shifting from Drive to Reverse and back w/ the brakes on.
Second would be something in the suspension.
Old Sep 4, 2012 | 12:10 AM
dkfire44's Avatar
Will I hear the noise in the u joint when I go fron drive to reverse? Because no I only hear it when I take off from a stop
Old Sep 4, 2012 | 12:21 AM
If there is excessive play in the U-joints, you can hear/feel it when reversing the drive shaft to take up the slop.
Old Sep 4, 2012 | 11:18 AM
Another possibility is greasing the yoke on the driveshaft. These trucks have a tendency to do this. Greasing the slip joint solved my problem.
Old Sep 5, 2012 | 12:11 PM
spyncycle's Avatar
Check the shock mount bolts at top and bottom.
Old Sep 6, 2012 | 10:12 AM
SWHouston's Avatar
I'd take a look at the Upper Control Arm Bushings... all 4
Old Sep 7, 2012 | 9:26 AM
Official GM Rep
Any luck getting this resolved since your last post, dkfire44?
Sarah (Assisting Louis), Chevrolet Customer Service
timabrams
Uplander
Dec 7, 2011 4:11 PM
lumina38
Jun 24, 2011 12:32 AM
fsh4fun05
May 1, 2009 11:22 AM
Gypsy
Apr 8, 2008 9:56 PM
