Has anyone installed a Kenwood 8120 GPS yet?
Old Nov 16, 2008 | 7:57 PM
  #11
guvner's Avatar
Default RE: Has anyone installed a Kenwood 8120 GPS yet?
At the risk of sounding like
an ad for Crutchfield I removed the
prices. Any advice on the stuff listed is
appreciated... I got the cable made up to allow the reuse of
the factory XM antenna. I also decided I didn't need the
8120 as the 7120 wasn't much different for my needs. Only
3 differences. 2 year warranty, output voltage if you're using
a different amp and 1 usb instead of 2.
Guvner..
120OSLAN02
Metra GMOS-LAN-02 GM Onstar LAN Data Bus Interface
What's Included
127GMRVD
PAC GMRVD GM Rear Seat Video Retention Adapter
What's Included
669PP500
Posi-Products Connector Kit 16 pieces for Car Stereos
What's Included
042DM4022
Pro.Fit DM-40-22 Trim Tool Trim panel removal tool
127SWIJACK
PAC SWI-JACK JVC/Alp/Clari/Ken Steering Wheel Radio Control Interface
What's Included
700XMKENV1
700XMKENV1 XM Package for Kenwood
0.00
113XM100V
Kenwood KCA-XM100V XM Adaptor for '08 Video Head Units
What's Included
220CNP2000
XM CNP2000 Mini Tuner XM Satellite Radio Cartridge
What's Included
ServiceNet 5Yr Service-Car AV Car Audio ($501-$1000), DOP
113BT200
Kenwood KCA-BT200 Bluetooth Hands-Free Interface
What's Included
CHEV TAHOE/YUKON 07 MS
0.00
142GM1598B
GM/Chevrolet 2006-up, E/DD 2006-up, E/DD
0.00
12040CR10
Chrysler Antenna Adapter Motor Motorola M to OEM antenna F
What's Included
0.00
000PERIG
FREE Crutchfield Guide: Peripherals Installation
0.00
000SRADIG
FREE Crutchfield Guide: Satellite Radio Car Installation
0.00
000NAVIG
FREE Crutchfield Guide: In-Dash Navigation Receiver Installation
0.00
000MVIDIG
FREE Crutchfield Guide: Mobile Video Installation
0.00
000SRSAIR
Airbag Fact Sheet Crutchfield Crutchfield Air Bag Fact Sheet
0.00
707VTL400
Boyo VTL400 Zinc Chrom License 2.8mm adjustable
What's Included
0.00
00075OFF
75 Merchandise Credit
-75.00
AAAFA26
Refer a Friend Offer
0.00
000CARCAT
Current Crutchfield Catalog Car Bounce Back
0.00
Old Nov 17, 2008 | 11:51 AM
  #12
shawnvw's Avatar
Banned
Very nice package. The Lan-02 module should work nicely, they are pretty easy to install. The harness for the rear video seems a bit pricey but worth it if you don't like the idea of soldering RCA's to the harness. If you want to save the $40 we can gie you pin-outs. Alsoa tip for that part of the install, when powering up the infared tranmitters, you have to by-pass the module as the output is not strong enough to power both the screen and the transmitters.
Don't buy the butt connectors. They are the devil! haha Seriously, twist\tape the wires so you are sure that you have a solid connection. Some people swear by them, I hate them. I have seen so many problem caused by butt connectors and T-Taps(or scotch locks).
Also looks like you're gettin 2 XM kits. one that comes with a home kit and one without.....make sure you're not paying double
one last thing that I see you're not getting and is a must have...the dash kit!
http://www.crutchfield.com/App/Produ...8B&tp=3121
Good-luck with everything man
Old Nov 17, 2008 | 5:18 PM
  #13
Soldered splices w/ shrink tubing are good.
Old Nov 17, 2008 | 6:27 PM
  #14
guvner's Avatar
Thanks for the comments guys... One thing I'd like you to tell me more about Shawn is the comment you made...
"If you want to save the $40 we can gie you pin-outs. Alsoa tip for that part of the install, when powering up the infared tranmitters, you have to by-pass the module as the output is not strong enough to power both the screen and the transmitters."
Can you supply the pin outs so I can just know what got done for me and in case I don't like the job the adapter did? And can you put up a wiring diagram of what wires need to be re run that are not able to carry the load for the screen and the transmitters?
Thanks for all of your help...
Old Nov 17, 2008 | 6:59 PM
  #15
guvner's Avatar
I should have asked this above but forgot.. The connectors question... Do you guys not like standard wire nuts? Do you recommend just twisting them together and soldering?
Thanks... Gary
Old Nov 18, 2008 | 5:17 PM
  #16
shawnvw's Avatar
Banned
Wire nuts are used in the home, not in the car. splice\soldering is the best\only way to go in the car
As for the video wires, I'm assuming you only have 1 overhead screen, if you have 2 i'll post more info later
in connector C3 (GRAY)
PIN 7 DK GRN Video (+)
PIN 15 WHT\BLK Video (-)
PIN 3 LT BLU Audio Left (+)
PIN 4 LT BLU Audio Right (+)
PIN 11 LT BLU Audio Common (- for both left and right)
in connector C1 (BLACK)
PIN 6 WHT You need to cut this wire and install a relay to amplify the power to the video accessories. The radio side of the wire should trigger the relay on pin 86. Pin 85 should go to ground. Pin 87 will go to the vehicle side of the white wire. And pin 30 will go to 12V
You must drop the over head video for this next part
Pin 4 (Pink) of the infared emitter module Must be cut and tapped into the white (PIN 8) wire of the video screen
Old Nov 18, 2008 | 5:46 PM
  #17
guvner's Avatar
Thanks for the above info. I'm assuming that I will use the adapter on the video wires. What has me concerned is that you are saying that the one part won't work with it and it sounds like that is that part that will have to be gotten to on the above (one middle) DVD player. Are the pin 4 and pin 8 you've mentioned in the above DVD player and just have to be connected up there?
Thanks... Gary
Old Nov 18, 2008 | 7:00 PM
  #18
shawnvw's Avatar
Banned
They have to be connected up at the video screen itself. But you also must use the relay to amplify the power to the white wire as I stated or you will have no audio for the wireless headphones.
Does the vehicle have 2 overhead screens or just one?
Old Nov 18, 2008 | 8:22 PM
  #19
guvner's Avatar
Just one screen Shawn... Thanks... I am asking questions blind though as the tracking number says it will all be here tomorrow...
Thanks... Gary
Old Nov 18, 2008 | 8:26 PM
  #20
Recommend heat shrink tubing instead of tape after soldering splices.
