Help! Sudden MPG drop
Go to your favorite auto parts store as most will scan for free to determine what DTCs have been set. That will give you a place to start although it won't necessarily tell you what part to replace.
73shark I wen't to O'Rielly's and they hooked it up to a little gizmo and the guy told me that I have to replace the fuel cap and then bring it back and he can reset the codes. Unfortunately, I need to replace it with the same factory cap (so I need to get one from the dealership). Does this seem right to you?
Did you ensure that the cap was on tight by tightening at least two clicks? If it's not the cap then probably the evap system. Search the forum as there is a lot of info on this and how to replace.
I'd make sure the cap is tight and have the error cleared, if it returns then I would pursue replacing the vent valve... DO make sure the sealing ring on the gas cap is clean and that you get several clicks when tightening, also ALWAYS stop filling when the pump shuts off... topping off after pump shut off can force fuel into the vent valve causing the failure...
archrmike
Jun 17, 2015 1:14 AM
OSU_METGRAD
11
Feb 18, 2010 3:51 PM
