High Pitch Noise~
Old Jun 29, 2008 | 7:37 PM
Cole11's Avatar
Default High Pitch Noise~
Hey ya'll.
I have a 1999 Tahoe LT 4-door 4x4 with a 3" body lift and it has 33/12.50 Tires. In the past month or so it has a really loud high pitch sound coming from the front driver's side wheel area and when I'm slowing down it goes into a low-pitch long sqeak. The squeak only occurs when the wheel rotates past a certain point then it goes quiet, then it squeaks again. There's absolutely no wobble or 'shimmy' in the steering wheel and I replaced my brake pads last week.
The fluids are all spot on and I replaced my idler arm, pittman arm, and the ball joints within the past month.
My mechanics have taken a look at it and they are completely perplexed as to what to do. They suggested that the brake rotor may be warped and that I should go get it 'trued'. Before I try that I though I should seek some advice from fellow owners to see if anyone else has found this problem and successfully fixed it.
Thanks in advance to any help ya'll provide.
[IMG]local://upfiles/18697/F7B2A408EE1D4E8F9D720ECD095D150F.jpg[/IMG]
Old Jun 29, 2008 | 11:49 PM
Default RE: High Pitch Noise~
Welcome to the Tahoe forum. A warped rotor will usually cause a pulsing in the brake pedal which is most noticeable right before you come to a complete stop.
Old Jun 30, 2008 | 1:34 PM
old dog's Avatar
i might look at the dust shield for the rotor ,it might have gotten bent during or after the lift ,or the wheel possibly rubbing the caliper ?
Old Jun 30, 2008 | 5:06 PM
Cole11's Avatar
Thanks for the info.
I forgot to mention that it has been lifted for a little over three years and has just recently started making this noise. The tires and rims have been on the truck for a few years so I don't know what's goin on.
I'll check what ya'll advised. If anyone has anything else please share.
Old Jun 30, 2008 | 7:31 PM
old dog's Avatar
the only other tjhing i can think of is the wheel constant velicity joint going out or out of lube ! or internal locking hub components dry .
Indianaman
Apr 20, 2022 6:23 AM
15suburban
Jan 21, 2015 8:49 AM
mpunt
Sep 20, 2012 5:13 PM
Tim1981
May 29, 2011 10:40 PM
RedOctober
Nov 12, 2009 4:12 PM
