high pitch noise from driver side dash, increases when accelerating
Old Sep 17, 2012 | 11:14 AM
mpunt's Avatar
Default high pitch noise from driver side dash, increases when accelerating
2008 Suburban LTZ
Every now and then I get a very high pitch buzz from under the driver side dash. When I accelerate the noise gets louder and higher pitched. If I smack the lower center dash (the part that has the change holder and cup holder) the noise stops. It's really frustrating. It's not a dvd or anything. Sounds electrical. Any help would be appreciated.
Old Sep 17, 2012 | 1:21 PM
kevinkpk's Avatar
Does it do it all the time with radio off, on?
Old Sep 17, 2012 | 1:28 PM
mpunt's Avatar
It doesn't do it all the time, but it has happened with radio on and off.
Old Sep 17, 2012 | 2:52 PM
kevinkpk's Avatar
Ok so it's not coming from a speaker. Increase in pitch with acceleration means it (whatever it is) is tracking the ignition. My "guess" is either a loose ground wire to cab, or if the ignition wireing is shielded, a ground issue on the shield.
Old Sep 17, 2012 | 3:47 PM
mpunt's Avatar
Nope, not a speaker. Best guess is that it is something under the center console a foot below the radio. At least that's where I hit and it stops (until I start the car again, when it's happening). That's the other weird thing...it only happens once per car ride.
Old Sep 20, 2012 | 10:57 AM
Official GM Rep
Originally Posted by mpunt
2008 Suburban LTZ
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> mpunt,
I agree with "kevinkpk", sounds like a ground wire issue. I encourage to you consult with a certified technician for an official diagnosis.
If you have any additional questions, please feel free to contact me privately.
Please keep us posted.
Louis
GM Customer Service
Old Sep 20, 2012 | 5:13 PM
mpunt's Avatar
Thank you!!!
Indianaman
Apr 20, 2022 6:23 AM
15suburban
Jan 21, 2015 8:49 AM
Tim1981
May 29, 2011 10:40 PM
RedOctober
Nov 12, 2009 4:12 PM
Cole11
Jun 30, 2008 7:31 PM
