Last edit by: IB Advertising
- Chevrolet Silverado GMT800, GMT900, and K2XX How to Install a Navigation System
How to install OEM Nav on 2007 Tahoe
#221
YES AOEM-1416 IS CORRECT TO HOOK UP YOUR AMP....JP CUSTOMS WILL HAVE IT PH#281-533-9900
YOU DIDN'T NEED TO GET THE BOSE AMP THAT MUST HAVE COST A FORTUNE????
AN AFTERMARKET AMP WOULD HAVE BEEN FINE....I GOT A BRAND NEW 600WATT FOR $60 ON LINE
#224
For those of you that are going to wire the head unit I found the radio connector diagrams at this web site:
http://www.installz.com/get.php
#225
Hey guys, sorry to bring up a LONGGGG reported post, but I just bought my new vehicle and needed some guidance.
I bought a 2007 GMC Yukon, which came with rear entertainment system in the headrests, and DVD loads into the head rests themselves. Can run 2 different DVDs at the same time (one in each headrest). It also came equipped with the Bose system. I am looking to add the NAV system, and rear parking camera. My question is which parts would I need? Would I need the 15940102 NAV system since I have rear entertainment system already????
Thanks in advance for any and all help!!
Don
Don
#226
i just installed a navigation system in my 2007 Tahoe with backseat entertainment system. I have two questions and would really appreciate any / ALL information that you have.
1) everything works great with my navigation( 15940102) except it doesn't have voice reconization. Is there a fix to this problem?
2) also has anyone ever installed a camera to this system and if so have you run into any problems.
a big THANKS
Patrick
a big THANKS
Patrick
#227
Do you have the VSS wire connected properly? How are you using the voice command? You have to press the button on the right of the steering wheel (the one above the radio plus & minus volume controls), wait for the beep and say "Navigation go to Phoenix Arizona" (which would have been already programmed into the address book and a voice tag added in the address book).
For the aftermarket Kenwood CCD-900 camera install - I posted earlier directions with pictures on how I did it - you can find it here (it is a Word document) http://home.earthlink.net/%7Egenesto...ra_install.doc
Hope that helps some
Gene
Gene
#228
[/align]i have no idea about the VSS wire --- could you explain further what i have to do. i did try that voice button but it states no voice detected.[/align][/align]thanks[/align][/align]Patrick[/align][/align]pat130@aol.com [/align]
#229
Here is a link when I did mine on this forum https://chevroletforum.com/m_5604/mpage_16/key_/tm.htm
who installed yours? I am surprised that the nav works without it.
Also the voice commads have to be already programmed into the address book location - have you done that?
#230
What happens when you press the button and say "Onstar"? It should come back and say "Onstar Ready" if it does not then you have other issues and I would take it to the dealer because that would have nothing to do with the nav unit unless somebody did something to the Onstar box while installing the nav unit.
