Last edit by: IB Advertising
- Chevrolet Silverado GMT800, GMT900, and K2XX How to Install a Navigation System
How to install OEM Nav on 2007 Tahoe
#402
NON bose nav/dvd is not available. When they first came out they could be programed for non amplified, amplified or lux bose amplified. GM took away the option for non BOSE Audio programing.
#403
thanks shamnvw for the help i ended buying a vss from oem-gm-radios for $68.00us + shipping. the guy says it is also pre-wired for the back up cam.know i would like to get one hooked up i looked under the pass seat and i dont think i have the right module.what can i do can i get it or a after market one that will work with the factory system?
#406
Charlie, Can I get one of the first ones that could be programed, non amplified? Will it work in 08 Silverado LT non Bose? Thanks for the help. David Cole
#407
a google search turned up this website.
http://www.mobilevideo4less.com/backup-cameras.html
The one that I use is similar to the RVC1000, its pretty close to the size of the factory, and it'll mount in the factory location.
You need to have the dealer reprogram your radio to turn on the backup cam
#408
I am still waiting for my head unit to arrive ups sucks I bought this thing feb 15 it was soppose to be here to day I am in EDMONTON CANADA I have been reading these threads for a wihle know each one is a little different but i hope when the time comes i will be good to go.So when i take this in to the dealer to get it unlocked ,can they unlock the camera part before the camera in stall? Also how do i get a thread started i plan to take pics of this install?
#409
If not then you will need to add a aftermarket amp or OE amp.
#410
the option for programing these nav radio's is no-longer available in gm tis 2 web. As long as your vehicle is amplified, it does not need to be bose amplified, nav radio can be programed to work with the vehicle.
If not then you will need to add a aftermarket amp or oe amp.
