Last edit by: IB Advertising
- Chevrolet Silverado GMT800, GMT900, and K2XX How to Install a Navigation System
How to install OEM Nav on 2007 Tahoe
#411
I would like to know if a guy were to take out the factory deck and put in a nav unit just to power it up to check if the thing works when you go to reinstall the deck will it lock? (theft-lock) reason being not quit ready for the real install
#412
If radio is not programed to vehicle and you connect the radio it will verify the vin it already knows and see they do not match and lock it self. If radio is reinstalled in correct vehicle it will unlock when it reads the correct vin, usually when you turn ignition on.
#415
If you have UQ3, then your vehicle is non-amplified. The only way to add a GM NAV is to add either, the OE GM amp or add an aftermarket amp. I personally think the aftermarket is easier and cheaper. I have used Zapco amps and aslo used MTX amps.
Do you have any rear audio controls (for headphone jacks) usually only comes in vehicles with bucket seats.
#416
Charile:
Please confirm if NAV unit out (15940102) of a 2007 Denali which was equiped with a Bose Lux system can be reprogramed for a UQA equiped 2007 Tahoe with rear audio and roof LCD. If not, does anyone have the part number for the NAV unit which I can plug and play?
Also, does a dealership usually unlock the theft-lock without any fuss??
Thanks.
Thanks.
#417
Charile:
Thanks.
Thanks.
#418
Okay. So I purchased the 15940102 NAV unit from a guy on craigslist. Paid $750 and it comes with NAV disc. I hope I got a good deal on it.
I plan to install it in my Tahoe which is equiped with rear entertainment system, non-lux amp (non-Y91), Onstar, roof mount LCD.
At this point I understand that I need to have the unit reprogrammed for non-lux amp (per Charlie Pachanga and confirmed by local dealer service department) and unlocked. I assume I will need a GPS antenna, but am wondering if the Onstar GPS antenna will somehow interface with the NAV unit?
Where I am confused is: I understand that the VSS is the vehicle speed sensor, but what is the VSS harness? I will guess that the VSS harness is needed to connect the NAV unit to the existing VSS. I think this is needed to gain with voice recognition or voice commands??? I would like this feature so do I need anything other than the VSS wiring harness (ebay $75) or do I also need a seperate VSS or some other module that this harness connects to? Sure wish JP Customs was still around!!
At this point I am not expecting to add a rear cam, but I might use the aux input on the GEN5 for an after market cam.
Can Charlie or anyone else enlighten me?
Thanks in advance.
Thanks in advance.
#419
Thanks in advance.
Thanks in advance.
There are no other modules to buy. You will also need to connect a wire to the VCIM. The VCIM is the onstar module. it is under the radio, below the the a/c. You will need this for voice comands.
You do not need any extra harness its just wires and pins that go into their respective slots. Do you need the connector/wire harness and pins. I can make them and send the pin locations they go to with instructions.
#420
I am wondering if any one can help me with the wiring locations of the vss.The black box down by the pedals has a bunch of green and green with white,any way to tell whict is the one?PLEASE HELP!!
