Installing power running boards?
Old Oct 25, 2008 | 3:30 PM
thetahoe's Avatar
Default Installing power running boards?
I really like the power-retractable running boards on my mom's ESV, so I was wondering if it was possible to buy the Escalade/Denali power running boards and install them on an LT3 Tahoe with manual boards? I'm aware that the Tahoes do sport those in some models, so if the Cadillac ones don't work then I'd be fine with the Chevy ones. Basically I'm just wanting to know if any of the OEM GM power steps will be compatible with a Tahoe that has manual ones, assuming that there might be a power socket for them to connect to. Thanks!
Old Nov 2, 2008 | 4:55 PM
d1nonly34's Avatar
Default RE: Installing power running boards?
I think as long as you have the right size running boards you should be fine. There are 3 cables coming from the boards, I'm assuming they are power, ground, and door trigger. I plan on getting these also and installing them, let me know how it goes.
Old Nov 2, 2008 | 5:31 PM
thetahoe's Avatar
Well, I got under my Hoee with a flashlight and checked out the boards, I didn't see anywhere on the vehicle itself where cables would connect. But you would think the factory would assemble it with them in case the consumer wished for the dealer to install the power running boards, and since the LTZ models can get these. Maybe I overlooked the adapters.
Old Nov 2, 2008 | 9:22 PM
charlie pachanga's Avatar
There is no wire harnesspre-wired from assembly line you must hard wire.
Old Nov 3, 2008 | 3:34 PM
txguykev's Avatar
Just FYI.....there are aftermarket retractable running boards at Amp Research. I know you wanted OEM but I have seen these on a few show vehicles and they seem to do the trick.
http://www.amp-research.com/products.../powerstep.asp
Old Nov 3, 2008 | 11:39 PM
thetahoe's Avatar
Yes, the aftermarket ones I have considered but oddly I can find the OEM ones cheaper so I thought those would be easier as well. I'll end up getting aftermarket if I can't get the OEMs hardwired [thanks charlie and txguykev].
Old Nov 5, 2008 | 4:20 PM
MalibuMaxxSS's Avatar
should not be a problem we have installed them on 1/2 trucks, 3500 Diesles, tahoes, escalades...all worked fine
Old Feb 11, 2014 | 8:54 AM
JCPerformance's Avatar
Not to awaken this thread from the dead, but I would like to add the OEM power assist steps to a 2012 yukon SLT. Can you (MalibuMaxxSS) or someone help with part numbers please? I was just told by my dealer that they do not sell a kit , but the more I look (like here), it says I can do it.
Appreciate all the help in advance. How do I help my dealer do this?? And what is the typical cost involved?
Thanks again.
Old Apr 30, 2016 | 11:42 PM
jscaldwell1980's Avatar
I have a 2015 crew cab and have bought some GM off of a 2013 LTZ avalanche that was added about a yr ago. Do I need a wiring harness to make this work or will I have to hardwire it. Any help would be appreciated
Old Sep 22, 2024 | 5:09 PM
_GMAN_'s Avatar
I am awakening this thread after an eight year slumber. I’ve purchased some factory running boards from a 2012 Suburban. I am looking for anyone that has a vehicle with these and would be willing to add some photos of their switches. I am looking to see if there are any particular dash controls that I need to look for.
HoleInOne
Apr 19, 2015 10:35 AM
Lopeze
Avalanche
Jul 22, 2012 6:52 PM
NorthWoodsDave
Dec 1, 2010 10:31 AM
biged412
Sep 7, 2010 11:04 PM
gmarcucio
HHR
Dec 30, 2006 2:56 PM
