Just Changed Oil & Now it says "Engine Oil Low" "AD ENGINE OIL" but its full!?
i just changed my oil on saturday, after the change it says on the speedo "Engine Oil Low" "Ad Engine Oil"
but i checked it & its fine, is there a way to reset this or what? its getting me nervious.
You should be able to scroll through to the "Engine Oil Life Remaining" on the DIC then press and hold the check mark button down until it resets to 100%. This button is the bottom button of the four to the right of your instrument panel.
There is an oil level sensor in the pan, if it is triggering the "Low Oil Level" warning then either you are more than 1 quart low or the sensor is faulty.
i reset the "Oil Life" & its been at 100%, i also checked the dip stick & the oil is high so it dose not seem a quart low?
drgnflys
Nov 26, 2014 12:52 PM
mystikalraven
10
Jun 29, 2010 8:10 PM
d1nonly34
Jul 15, 2009 12:33 PM
BlackDenali
Sep 20, 2007 12:11 PM
