Just Changed Oil & Now it says "Engine Oil Low" "AD ENGINE OIL" but its full!?
Old Apr 23, 2007 | 5:49 PM
larry_chip's Avatar
Default Just Changed Oil & Now it says "Engine Oil Low" "AD ENGINE OIL" but its full!?
i just changed my oil on saturday, after the change it says on the speedo "Engine Oil Low" "Ad Engine Oil"
but i checked it & its fine, is there a way to reset this or what? its getting me nervious.
Old Apr 23, 2007 | 6:47 PM
jmitchell's Avatar
Default RE: Just Changed Oil & Now it says "Engine Oil Low" "AD ENGINE OIL" but its full!?
You should be able to scroll through to the "Engine Oil Life Remaining" on the DIC then press and hold the check mark button down until it resets to 100%. This button is the bottom button of the four to the right of your instrument panel.
Old Apr 23, 2007 | 7:45 PM
ZX1100F1's Avatar
There is an oil level sensor in the pan, if it is triggering the "Low Oil Level" warning then either you are more than 1 quart low or the sensor is faulty.
Old Apr 24, 2007 | 2:17 AM
larry_chip's Avatar
i reset the "Oil Life" & its been at 100%, i also checked the dip stick & the oil is high so it dose not seem a quart low?
Old Apr 24, 2007 | 2:23 AM
Like Dave said, get the sensor checked.
Old Apr 24, 2007 | 9:33 AM
07LTZGREYSTONE's Avatar
Larry , you dont want to disconnect your oil sensor too now do you??
Old Apr 24, 2007 | 11:46 AM
larry_chip's Avatar
lol
drgnflys
Nov 26, 2014 12:52 PM
mystikalraven
10
Jun 29, 2010 8:10 PM
d1nonly34
Jul 15, 2009 12:33 PM
Macross707
Sonic (Aveo)
Jul 8, 2009 7:01 PM
