new member 06 Burb rear hatch won't lock
Old Jun 21, 2020 | 6:29 PM
3Js's Avatar
3Js
Default new member 06 Burb rear hatch won't lock
Hi. First post.
I just picked up a 06 Suburban 1500. No owners manual. 148K miles.
The rear hatch works fine. Just doesn't lock. Before tearing off the rear hatch cover panel, Is there a fuse for the rear hatch lock actuator.to check first?
Doesn't sound like actuator is doing anything but I wasn't listening real close at the time.
Is this a common issue? One thing I don't like about this truck is no manual locks except for driver door.
Old Jun 21, 2020 | 11:05 PM
Rednucleus's Avatar
Our 05 Suburban had the same problem, turned out to be broken wires in the harness coming in to the door. Mechanic said it was a common failure point do to motion every time the door opens & closes.
Old Jun 22, 2020 | 7:41 PM
3Js's Avatar
3Js
I removed the rear hatch panels and found the actuator is getting power. I hear/feel it moving or trying to.
I will go ahead and order a new rear hatch actuator. In the meantime I was able to manually lock the rear hatch
Old Jun 26, 2020 | 10:07 AM
Silverfox103's Avatar
For what it's worth: a few years ago I bought a 2001 Yukon XL with barn doors. I went through it and got everything working big and small. After a year, the one thing I could never figure out was the doors, they wouldn't lock. Tried everything, pulled everything apart....no luck.
Then one day the Mrs. pulled in the driveway and I noticed one of the back license plate lights were out. I replaced it and from that day on the doors have worked perfectly. I have no explanation, other than problem solved.
Tom
Old Jun 28, 2020 | 4:27 PM
3Js's Avatar
3Js
Replaced the rear hatch lock actuator today. It definitely was the actuator but thanks for the other suggestions.
Back in business. Easy and painless swap.
DireWolf06
Jun 21, 2020 7:12 AM
remtlm
Jan 16, 2020 8:41 PM
slyde55
Uplander
Oct 18, 2018 2:17 AM
Wdh64
Aug 27, 2017 11:27 AM
GoFishRay
Feb 19, 2015 7:07 PM
