Passenger side mirror has a mind of its own?!
Old Nov 6, 2011 | 10:31 PM
kstough's Avatar
Question Passenger side mirror has a mind of its own?!
I just had to replace the motor on my passenger side mirror. Since then, it has a mind of its own. When I turn the car off, it turn to the extreme right. I can manually readjust it using the four-way button on the inside of the door, so the wiring seems okay. All attempts to set new positions using the programming button on the door fail -- the next time I unlock the car, the mirror moves back to the extreme right position. Any position I program it for is ignored.
I suspect this has something to do with some computer in the car. What's going on? What are my options for getting the mirror to behave properly again? Is this something I can correct myself? If so, how? Or will I have to take the car to a dealer? THANKS!
Old Nov 7, 2011 | 8:34 PM
Welcome to the forum.
What year and model? If it's the new GMT 900, it may require dealer programming.
Old Nov 7, 2011 | 8:44 PM
kstough's Avatar
2007 Tahoe LT
Old Nov 7, 2011 | 9:02 PM
kstough's Avatar
Do you think it may fix itself if I reset the ECM or BCM?
Old Nov 7, 2011 | 9:12 PM
I think it requires programming at dealer.
Old Nov 11, 2011 | 8:49 PM
kstough's Avatar
Bummer, hate to take to the stealership. We have been there way too much lately
Old Nov 18, 2011 | 9:38 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> I also would suggest visiting the dealer. Better safe than sorry.
Louis
GM Customer Service
05cavalier
May 20, 2015 1:42 AM
Bradc80
Sep 25, 2012 12:40 PM
98whitehoe
Mar 14, 2012 7:48 AM
Buckhorn
Nov 6, 2011 8:23 PM
SWHouston
Jul 8, 2011 9:21 AM
